How Do I Tell Which Gears My Z28 Has Out Back?
go look at the code list on the end of the door. get the GUx code (code will be GU then a single digit).
i *think* the following codes mean the following gears (not sure, but i'm sure someone will correct me if i'm wrong):
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
Originally posted by StormSigma
Thanks, I'll go check right now. Also a good question, which are the more desirable ones to have?
thanks 99blackSS, GU2 is 2.73
![Arrow](https://www.camaroz28.com/forums/images/icons/icon2.gif)
GU2: 2.73
GU2: 2.73
Don't remember where that is right now, though...
![Frown](https://www.camaroz28.com/forums/images/smilies/frown.gif)
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
This might be of help, too... http://www.f-body.org/gears/
TS
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
Originally posted by mullettour
A4's didn't come from the factory with 3.42 gear ratio. Only 2.73 or 3.23. The 3.42 was in the m6.
Ok we were ALL wrong. I just called the local Chevy dealer. I have the 3.23 rear end. The code for that is GU5, the 3.42 gears are actually GU6.
Oh, and the Positrack option is designated by the G80 code. I have that too.
It must be true ... it's written down on paper
Oh BTW it's the factory manual .
I like my 2.73's i can almost pull a 2.0 60ft (think it's like 2.045) with stock drivetrain and stock suspension, with the few mods listed below, plus i get better gas milage and can go 160+mph<<<<<<<like you need it...lol
ChrisFrez
12-15-2014 03:09 PM
07-04-2005 05:00 PM
1LEThumper
07-14-2003 12:45 PM
