crank sprocket
Re: crank sprocket
And finally, nope, the crank sprocket will NOT just slide off after the cam sprocket and timing chain have been removed. Again ...... you need a puller to remove the crank sprocket.
Re: crank sprocket
Like the others said, use a puller and maybe apply a little heat to it if it's giving you a lot of trouble. Installing was easy, I didn't want to bang on it with a hammer so I put the gear into the toaster oven for 15 minutes on high and it went on really easy with minor tapping.
Ryan Ramsaran
09-19-2015 08:43 PM
