ICM grease?
ICM grease?
Anyone know what kind of grease goes between the ICM and the heat sink it mounts to? Just ordered a brand new GM ICM cuz I think mine took a crap, car died in the middle of the road .
partial definition of dielectric grease
In addition to the things listed it is used for a heat conductor when some electronic components are mounted on surfaces to dissipate heat (like the ignition power stage on 700/900 models and 240's 89-93). It is non-conductive, but when you slide the connectors together there is metal-to-metal contact and the grease gets displaced but the area around connector is protected from moisture.
I kinda figured the grease came with it, I just wanted to get some extra for the ICM on there now so my car doesn't die in the middle of nowhere. I'll see if I can find some thermal grease or something at Autozone.
Nayr
03-03-2023 08:34 PM
Ryan Ramsaran
09-19-2015 08:43 PM
tdigger9899
09-07-2015 10:56 AM
