Voltage to data port?
Anyone have the voltage values that you are supposed to get to each of the pins at the aldl port? With the ignition off, i got nothing except for 12V to pin #16. When i turned the key "ON", i got 5V to pins 6 and 9 in addition to the 12V to pin 16. Does this seem correct?
Courtesy of shoebox
Courtesy of shoebox
4 and 5 should be grounds and you would probably see 5v on 2 (again assuming it is an OBD-II DLC-you never confirmed).
If wired properly pins 5 and 9 are the only ones you need to scan OBD-I.
http://shbox.com/1/1995_pcm1.jpg
Yes.... ALDL = DLC. There is a picture of one above, and you asked what the "DLC" was, so I thought that would be very clear.
08-07-2015 01:26 PM
