A few odds and ends for sale/trade
Old 01-30-2008, 03:26 PM
SoccerFEtus8's Avatar
I have some various LT1 parts left over from some projects.
Remanufactured by GM ABS control Module from 93 camaro gm part # 16171460
ABS "motor" for lack of a better term. The big chunk that mounts in the engine bay and performs all the ABS magic. I also have the bracket that it mounts on.
Air clearner stock box/pipe/elbow. The box and pipe look fine, the rubber elbow is ripped where it connects to the intake.
Power steering pump with pulley, reservoir, and pipe that connects the two together. No return line to the rack.
E/Brake handle. No cable or bolts. Greyish/black handle.
Stock shifter, i don't believe i have the **** for it, but the rest of it works.
Wipers. Everything is there i believe. Motor, arms, blades, and i think I have most the bolts for it all also.
I have a center consule I got from a salvage yard thinking i was going to use it but ended up with a different set up. The storage compartment lid hinge is broke but everything else is in pretty good shape. Just needs to be cleaned up. Would rather not ship this item due to it's size, but if you want to pay for it be my guest.
Rear seatbelts, grey in color.
Make any reasonable offers and this stuff is yours. I am looking for some bolt in SFC's if anyone wanted to trade something.
SoccerFEtus8 is offline
Old 01-31-2008, 09:29 AM
LT1 stuff
I also have a passenger side airbag.
And all the parts and pieces for heat/ac inside the car. I removed everything so it is all there with the heater core and the plenum, and all the piping. No vents though, they stayed in the dash.
Old 01-31-2008, 11:13 AM
maverickmk's Avatar
do you have the hoses/pipes that run from the motor to the heater core and back again?
maverickmk is offline
Old 01-31-2008, 04:26 PM
Sorry I do not have those.
Old 02-01-2008, 03:01 PM
bump for friday afternoon
Old 02-13-2008, 01:04 PM
One last bump. I'm looking for pennies on the pound here guys. Make an offer or just come take it all for dirt cheap.
Old 02-15-2008, 12:38 PM
AHARTZ28's Avatar
how much for just the heater core?
AHARTZ28 is offline
Old 02-15-2008, 02:59 PM
I just pulled it out, looks good, I flushed some water thru it with a hose and went thru no problem so It isn't pluged or anything. Hows $35 shipped sound?
Old 02-15-2008, 05:00 PM
AHARTZ28's Avatar
sent you an email
AHARTZ28 is offline
Old 03-19-2008, 03:58 PM
bump. still got this stuff
Old 03-27-2008, 12:46 PM
fbodyracer19's Avatar
hey bro, I was referred to you by a buddy on LS1Tech. I am in a desperate need for airbags cheap for my 97 Z28, and I noticed you at least have a passenger airbag, how much do you want for it shipped to Abilene, Tx???
fbodyracer19 is offline
Old 03-27-2008, 08:00 PM
andysc's Avatar
looking for the console shifter plate. is this for a automatic and if so will you seperate.
tia
andy schuck
andysc is offline
10-31-2016 11:09 AM
Zrout
06-15-2015 05:06 PM
LingenfelterZ28
04-24-2015 12:14 PM
Hurin
12-13-2014 07:38 PM
guionM
9
08-29-2002 01:48 PM
Quick Reply: A few odds and ends for sale/trade
