T-56 Input Shaft
T-56 Input Shaft
I see I have some fluid leaking inside the tranny. I am guessing it is the input shaft seal. How hard is it to replace this seal. Is this one of these deals, if I try to take the shaft out and replace the seal, I am gonna have to deal with 100's of springs? Or is it as easy as removing the shaft and popping the seal and putting a new one in?
ZMAN Z28
An engine rebuild is not just a rebuild. You find 10 other little issues.
ZMAN Z28
Re: T-56 Input Shaft
You will need to partially disassemble the trans. Meaning taking the whole thing apart from the back foward but you wont need to take any of the assys apart! This isnt that hard if your handy with tools but its not just removing and replacing the seal.Oh yeahh you will need a set of tranny snapring pliers.
