95' Camaro 3.4l NEED HELP PLZ ! Knocked Something off the oil filter assemely ???
ok today it changed my oil filter from the top on my 1995 camaro 3.4l v6 and i knocked something off looks like a sensor or something has a wire on one end and is in a rubber plug and just sits on the oil filter assemely . now i have no oil pressure and oil is leaking for yje hole this sensor was in .
What is it ? how do i fix it ?
Thank you
Jason T.
Thank you
Jason T.
Re: 95' Camaro 3.4l NEED HELP PLZ ! Knocked Something off the oil filter assemely ???
thats your oil pressure sending unit. Never messed with mine on my 94 3.4 but if its already off just go buy a new one and replace it. You might wanna do a quick search around the borad as to how they are supose to attach onto the oil filter housing.
yep it was the oil pressure switch / send unit . the plactic just camapart around the nut flange , when i bumped it , needed to be replace anyways , if that think would of broke of during the car was running you woul lose alot of oil fast .
looks easy to repair just a open end wrench will do it .
Thak you
Thak you
Location: carbondale IL \ Alton IL (outside St Louie MO)
but its a pain to get a wrench on it.. trust me (note, dropping a header on the sensor will snap it like a twig)
So how much alike does the oil pressure sending unit look like the O2 sensors? What was described sounds like what I thought were O2 sensors, one on either side of the car threaded into the exhaust manifolds. Am I mistaken, or is one of those single wired sensors for the oil pressure??
If you knocked the oil pressure sensor loose, like my nephew did, it will gush oil out , its about $25 at autozone, they do sell a socket for it it is a really deep socket . it is a 1-1/16 size. if you have an automatic trans , you should be able to get a wrench on it, but if your a manual trans, you should look for the socket. best $12 i ever spent!
07-04-2005 05:00 PM
