Starting to part out 9 second Na combo, fast and top end
Old 02-18-2006, 02:37 PM
squinn's Avatar
Fast EFI package:
FAST/Speed Pro box bought in 1999, the box is labeled Speed-Pro, as that is what they were called before it was renamed FAST. You will get ecm batch fire box, LT1 race harness set-up for a crank trigger, wide band o2 and calmap cable. The crank trigger is a custom Holley hal effect with an 8" wheel.
Selling for $1400
Top end package:
GM LT1 cylinder head castings, ported by Modern cylinder head, combustion camber and exhaust port coated y Dart coatings
Manley 5/16 SD valves with new comp springs, 1.55, 300lbs on the seat and Manely Ti locks & Ti ret, bead lock style
T&D shaft rockers,1.6 ratio, XL option, oil squirters
Smith Bros push rods 5/16 .083 wall cm
B&B valve covers
Selling for $2200
Can be sold with heads or after heads have been sold
Edelbrock Vic E converted to efi with fuel rails will fit my LT1 heads $500
Cam Motion solid roller 263/271 on a 108 $250
More parts will be available after heads sell
This combo went 9.71 @ 138 on motor
Reson I'm selling, I'm building a gen I SBC na motor to replace this motor, I just need to go faster.
squinn is offline
Old 02-18-2006, 04:12 PM
Cmr0z28's Avatar
Re: Starting to part out 9 second Na combo, fast and top end
I'm interested in the intake. Can you send pics to unwrittenlaw6787@yahoo.com ?
What else would need to be done to fit it except for an elbow / intake tract?
Cmr0z28 is offline
Old 02-18-2006, 08:59 PM
Z284thgen's Avatar
email sent
Z284thgen is offline
Old 02-18-2006, 10:18 PM
n4b
n4b's Avatar
Can you please email me a number to reach you, My email is n4b2u@yahoo.com,Thanks
n4b is offline
Old 02-18-2006, 11:05 PM
squinn's Avatar
pm's sent
squinn is offline
Old 02-19-2006, 02:27 PM
rock1501's Avatar
Steve I will take the intake for sure if the heads sell
rock1501 is offline
Old 03-01-2006, 10:50 AM
96speed's Avatar
Quinn: Sent you a PM.
Ryan
96speed is offline
Old 03-01-2006, 12:10 PM
94_PatriotRed_Z's Avatar
Did you have an 1LE elbow? If so how much shipped to 27858?
Thanks
94_PatriotRed_Z is offline
Gtpguy
01-26-2015 04:50 PM
Collector Car
01-05-2015 10:58 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Starting to part out 9 second Na combo, fast and top end
