Finally in the 12's, new best everything...
Old 11-05-2006, 03:55 PM
1SlowFormula's Avatar
After a couple years of tweeking to try and get to 12's with the mods in my sig and not quite getting there I decided to actually do a few mods this summer.
I added 1.6 full roller rockers, Pacesetter Race long tubes, ORY, and bullet muffler, Poly mounts, and new plug/wires type tuneup. Plus a little weight reduction, but nothing major yet since I still retain all interior pannels, AC, and all bumber supports and safety equipmentincluding I still have completely stock suspension and 2.73 gears...
Race weight with me and 3/4 tank of gas in the car was 3490 and I have a good 200+ on me.
Too bad I was only able to get one good run in at Maple Grove, but I finally got into the 12's...
60'_____1.723
330_____5.124
1/8_____8.004
MPH____85.37
1000___10.503
1/4____12.628
MPH___105.85
And there is more in it with some more tweeking, but now I have to wonder what gears would do for me...
1SlowFormula is offline
Old 11-05-2006, 04:15 PM
bitchin94's Avatar
Thats f***ing fast for 2.73s Thats what Ive got in mine with whats in my sig and last night I raced a 89 mustang GT that runs consistant 13.9s. He said his car was running great and mine was running kinda hot and with some extra stuff in the back I still beat him by a car length in about and 1/8 mile and was starting to pull away. I want to do almost the same thing as you except 3.73s and a 2800 stall
bitchin94 is offline
Old 11-05-2006, 04:19 PM
T/A-Bob's Avatar
That's great! I hope (someday) to make it into the 12s myself (I still have a l-o-n-g way to go).
What tires were you using to get that 1.7 sixty-foot time?
T/A-Bob is offline
Old 11-05-2006, 04:25 PM
2000GTP's Avatar
Stock suspension, full raceweight, and 2.73 gears and you pulled close to mid 12s. Congrats on the nice times.
2000GTP is offline
Old 11-05-2006, 04:39 PM
MeanGreen97Z's Avatar
Very good.... I hope to be doing the same. I would say that with 3.73 gears you can pull a better 60 and maybe 2 tenths faster 1/4 mile.
MeanGreen97Z is offline
3 or 4 year old Nitto DR's mounted on stock z28 rims, with a lot of passes on them that I borowed from a buddy, he just had them sitting around since he got Draglites and ET streets mounted a few years back...
I can normally get a good 1.9 - 2.0 with cheep street tires though...
Old 11-05-2006, 05:38 PM
reamo04's Avatar
is this on a stock cam or what?
reamo04 is offline
Old 11-05-2006, 05:40 PM
2000GTP's Avatar
It appears he has a stock cam, bolt-on car. It goes to show you how valuble a higher stall converter can be to your setup.
2000GTP is offline
Old 11-05-2006, 06:16 PM
I'm thinking about the fuddle 3600 myself....
Old 11-05-2006, 06:40 PM
Motor is all stock internals w/ ~80K miles...
I have been slowly doing things to it for years, making sure I had the entire picture in mind, and was working off of the philosophy of when something either breaks or needs attention to upgrade to a performance part that meets my bigger plans, this is why I got the higher stall converter and all that. When I got it it was actually spec'd to work with a combo still not fully in the car yet (but getting there), and in talking to the tech's at PI I was assured it would only just stall a little little less until those goals are achieved, so the car is actually just starting to come together as a better combo since that converter was a little high for the previous mods...
Old 11-05-2006, 07:15 PM
CamaroRacing12's Avatar
that rear end is gonna go in a few more runs....hope u can afford to rreplace it
CamaroRacing12 is offline
Old 11-05-2006, 07:19 PM
I doubt it.... I know people who have cut 1.5x 60 foots for 100s of passes.
Old 11-05-2006, 07:49 PM
That depends on what you mean by gonna go...
The setup is strong and it will not break, but the LSD has been going out for a year now, and every few runs it doesn't lock up. But don't worry about it I have it covered...
Old 11-05-2006, 07:51 PM
T/A-Bob's Avatar
Just to make sure I'm following this... you ran your 13.17 with your converter already installed... ?? and you cut over half-a-second essentially just by adding long tubes and 1.6RRs??
T/A-Bob is offline
Old 11-05-2006, 07:53 PM
Daniel6718's Avatar
lol my stock 10 bolt with 3.73 stock posi and no girdle has been 1.62-1.64 on motor at least 15 times, and on n20 its been 1.52-1.55 about 5 times...on m/t d/r stock suspension saladshooters all the way around stock tq arm and lca
Daniel6718 is offline
Quick Reply: Finally in the 12's, new best everything...
