beware accel opti
Old 04-19-2007, 04:39 PM
nick3's Avatar
beware accel opti
i had it go out twice now and finally found out why. the shaft on the accel is an 1/8 inch longer then the stock opti. the cam was puting the pressure on it and causing the rotor button to heat up against the cap and bust. i will not buy one again
nick3 is offline
Old 05-28-2007, 11:23 PM
Dan Parker '96's Avatar
I've been running one for several thousand miles and 7K+ rpm (albeit connected to a Delteq). Hasn't blown up yet.
Dan Parker '96 is offline
Old 05-29-2007, 07:55 AM
2000GTP's Avatar
That is a pretty sizable difference.
2000GTP is offline
Old 05-31-2007, 01:45 PM
dannyum89's Avatar
I noticed that too when I was trying to install one on a buddies car. I could barely get the opti housing to touch the timming cover. Sent it back quick.
dannyum89 is offline
G-BODYT56
01-14-2022 11:14 PM
93 RedBird
11-15-2015 08:24 AM
Ks0209
10-01-2015 07:32 AM
colts0455
09-27-2015 01:07 PM
Matt Dreessen
09-09-2015 09:58 PM
Quick Reply: beware accel opti
