Letting one of my secerts out of the bag...
Old Apr 11, 2008 | 01:44 PM
BLUETOPTA's Avatar
In 2003/2004 I figured this out, and I feel I can now let this out now.
I run LS1 rocker arms on my LT1 motor. Yes 1.7 LS1 rockers.
To run them, you must drill out the bolt hole to the size of your rocker studs. 3/8 or 7/16.
You must then use the lock nuts that you would use for a set of standard SBC roller rocker arms. Cost around $40
Also GM PP guide plates ($45) and hardend pushrods if you have them or not.
Doing this is much cheaper then buying most aftermarket roller rockers. (Used LS1 rockers can be bought for cheap)
I have ran them on my car since 2004. No I dont have any pics, but trust me this has been working for me.
Just thought I would share this...
Old Apr 11, 2008 | 01:54 PM
jsetzer's Avatar
Interesting... I would still prefer a full roller rocker, but I guess if you stayed with 3/8 studs this could be pretty cheap.
1.7 might be too much rocker for most people with aftermarket cams... I am sure my baby cam would be fine with it though.
Old Apr 11, 2008 | 02:07 PM
mdacton's Avatar
I tried using stamped steel stockers and rollers....the rollers didn't make the car run any faster......
I wouldn't run stockers on anything big...but for a hyd. cam they work just fine
Old Apr 11, 2008 | 03:40 PM
The LS1 rockers are not stamped. They are investment cast steel. And I thought they were trunion rollers (not rips)????
Old Apr 11, 2008 | 03:47 PM
Colin91Z's Avatar
They are roller fulcrum but not roller tip
Old Apr 11, 2008 | 03:56 PM
Trunion = fulcrum
rips = tips (typo)
Old Apr 11, 2008 | 04:23 PM
joeSS97's Avatar
Good info for those interested in a cheap mod. As long as the rest of the valvetrain can support it.
Old Apr 11, 2008 | 09:51 PM
andysc's Avatar
Just curious, do you adjust the rockers like a traditional
roller rocker or do you just torque them down like some of the newer GM rockers. I have been looking into doing this with my stock cam and lt4 springs. What springs are you using.
tia
andy schuck
Old Apr 11, 2008 | 10:06 PM
shoebox's Avatar
tia
andy schuck
Since the studs are the same, it will have to be adjusted just like before.
Old Apr 11, 2008 | 11:31 PM
speed_demon24's Avatar
I wouldn't do this in a car with a decent size cam in it since the ls1 rockers are known for puking out their bearings.
Old Apr 12, 2008 | 01:10 AM
LSWHO's Avatar
Why not just get scorpion 1.7s?
Old Apr 12, 2008 | 08:22 AM
fastchevy's Avatar
cost
Old Apr 12, 2008 | 08:32 AM
mdacton's Avatar
MY point was going to a roller is not going to make much of a difference IMO. The ratio of the rocker arm will but "reducing friction" really never made a diff. on anything I tried.
Old Apr 12, 2008 | 11:23 AM
LSWHO's Avatar
Originally Posted by fastchevy
cost
$222 is too much!? If that's the case, maybe you guys shouldn't be modifying your cars. Also, you'd rather drill into your heads than spend a little bit extra?
I don't see the point.
Old Apr 12, 2008 | 11:31 AM
87bandit's Avatar
I'd trust an oem part vs aftermarket for reliablity, I've heard mixed things about scorpians
