New V6 Engine Bay Spyshots!!!!!!!
Old May 22, 2008 | 12:38 PM
punkdrum01's Avatar
Exclamation New V6 Engine Bay Spyshots!!!!!!!
Old May 22, 2008 | 12:46 PM
punkdrum01's Avatar
oooooops, sorry guys, didnt realize some already posted it under the production line spyshots.......although its probably worthy of it own thread.
Old May 22, 2008 | 01:15 PM
99SilverSS's Avatar
Def. looks like the 3.6L the question will be if it's the DI version at 300hp or the lesser hp variants above. Either way good V6 engines from what I hear.
A nice cold air kit would look a lot better than that huge airbox. Good start for the aftermarket.
Old May 22, 2008 | 04:52 PM
FAD1's Avatar
I hope it has a DI'ed V6. It has to have Direct Injection because if it wasnt, the HP rating would be around 260. Thats the same as the Cobalt SS. I dont think GM will let that happen.
Old May 22, 2008 | 08:53 PM
FAD1's Avatar
Just Beautiful
Old May 22, 2008 | 09:17 PM
embpic's Avatar
I really think now that this is the DI V6. Look at the top of the valve covers. You will notice that there appears to be an electrical connection for each cylinder. In the cutaway view of the DI V6 you will see these same connectors. I believe these are the direct injectors.
Old May 23, 2008 | 09:50 AM
82lt1ta's Avatar
Decent looking motor
Old May 23, 2008 | 10:28 AM
Geoff Chadwick's Avatar
Where'd they stick the battery? Trunk?
Old May 24, 2008 | 12:32 AM
GMRL's Avatar
Engines aside, we can clearly see Zeta here. Stating the obvious, but cool none the less.
Old May 24, 2008 | 01:05 PM
99SilverSS's Avatar
Good pics. It does seem to show a certain similarity between the Zeta based vehicles. Very obvious around the firewall.
I just hope that GM goes cheap and leaves off all that plastic used on the G8 for the Camaro. I don't want an engine cover and I don't want the whole engine bay covered by plastic panels. It just adds useless weight and cost IMO. I loved the look of the LS1 in the F-body as opposed to the Vette because they left off the engine cover but then you could actually see the engine. Although not beautiful the LS engines are not bad looking either.
Old May 30, 2008 | 07:55 AM
IZ28's Avatar
Yes.
Old Jun 2, 2008 | 05:36 PM
Rich97 W68's Avatar
Eternal Member
That intake manifold looks suspiciously similar to the one used on the 4th generation 3.4L.
Klypto
Mar 23, 2016 09:05 AM
alex5366
Mar 8, 2015 11:32 AM
formula218
Dec 2, 2014 04:27 PM
kandied91z
Aug 4, 2002 02:53 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
