New GM LT1 Crate Engines
Hello,
As our introductory to CamaroZ28.com we are offering a sale on GM crate LT1 Engines. These are not used/remanufactured, but new in the crate long block engines. They are GM part number 88894195 and are a direct replacement for a 1995 F-Body. They can be used in the 1993-1994 if you are running a vented opti-spark, or a 1996-1997 if you change the front cover, crank hub, crankshaft reluctor, and crankshaft position sensor. We will be selling them at the amazing price of $1795.00 plus shipping until all stock is exhausted. Along with this we are offering an additional 10% off ALL Comp Cams products with the purchase of an engine. For pictures and more information click on the link below.
Also don't forget about the 3 yr 100,000 mile warranty.
http://www.trademotion.com/partlocat...catalogid=6440
I still have a few in stock. As for the warranty it would only be valid out of the car. Meaning that if it does have an issue two years from now you would have to remove the engine and take it to the dealer. Then they would cover it parts and labor from there. In a 1995 you just need the invoice and the car and you are covered for 3yr/100,000 miles R&R included.
hope this helps
X2. Wondering the same thing. i'm in need of a long block. this would be perfect.
Yes, these are all 4 -bolt mains!!!! Just a smoking deal...
Thanks
