SLP 2OTL exhaust F/S or Trade
SLP 2OTL exhaust F/S or Trade; PICS ADDED
Ive got the nice, rare and expensive 2otl exhaust that I pulled off the car today up F/S or willing to trade. Im wanting to do an X-pipe with dumps so if u have that than maybe we can work something out. Also willing to consider some other stuff besides exhaust + cash depending on what u got. Im thinking $250 + shipping is a fair price for this system.
Part of the OTA pipe will need to be removed from the muffler; im going to try and get it out tomorrow.
It does some scratches on the underside but not noticeable once on the car. There are no dents on any part of the exhaust; Might be able to clean it up better than I did. I just cleaned with soap and water if u have some time to clean it up completely than Im sure it will look better than what the pics. show.
So WHAT U GOT!
lmk
sean
So WHAT U GOT!
lmk
sean
90,000 I had to cut it off at the end of the over the axle pipe to get it off but I will supply u with the OTA pipe if u need it. No problems with the exhaust, sounds great. Already deleted the cone of silence so thats one less thing that u would have to do.
Im only assuming it has that many miles on it. I just bought the car in january so its possible it been replaced cause it is in excellent shape. If u decide u dont want the muffler than make me an offer on the OTA pipe. I will get pics of muffler as soon as i can.
lmk
lmk
Sorry ive already got all my motor bolt-ons. All I need for motor is set of ported & polished Heads, 36lb injectors, and a MONO Blade TB. I could also use STB, T-Top headliner, Dash pad, Aluminum DS, LCA Relocation brackets, 17x11 ZR1's, Harness bar, 5 point harness seatbelt. X-pipe w/ dumps or just an X-pipe.
I would be interested in any of these things Ive mentioned for trade or $ of course.
I have this 2OTL exhaust and it sounds absolutely great! Pretty loud at idle, but doesn't get a too much louder as the RPM climb while driving ...and no drone! I also have a hollow cat too. I am unsure as to why you had to cut the OTA pipe? My exhaust has a slip fitting right at the OTA pipe making it easy to remove. Also not sure of the cone of silence, what is that? I looked into my muffler and did not see any restrictions. I would think the mileage would not matter. My exhaust was used and it looked, and still looks new. I think it is made of the non-rusting 304 stainless. This is high quality SLP stuff. Didn't want to hijack the thread, just wanted to give my high recommendation for this exhaust system. Good luck, Shimaze
JaysZ28,
I can ship anywhere in the US for about $50 through some covert shipping.
Shimaze,
I had to cut it off because the clamp was put on pretty tight and I didnt have a torch to heat the metal.
Zeetwentyfate,
Im not really looking for rear exit exhaust but u can send me pics and ill consider it. Got anything else?
Transam1577,
Im located in San Marcos, it between austin and san antonio if ur not familar. Im just looking for the plastic dash pad I dont need the entire dash.
I will get pics up this afternoon after I get off of work.
Shimaze,
Zeetwentyfate,
Transam1577,
