A4 conversion parts
Old 01-19-2009 | 09:06 PM
Chevyguy358's Avatar
A4 conversion parts
I have everything needed for an A4 conversion except the trans. All parts are from a 94 camaro. I'm prolly forgetting something but I should have it all as I just did a 56 conversion. I'd like to get $250 out of it if purchased together. Pm me if interested
-Crossmember and mount
-torque arm mount
-shifter
-cable to tranny and cable to safety switch
-console shift plate
-pedals
-aftermarket flex plate
-driveshaft if desired
-transmission cooler and lines with fittings
*I should have the wiring connectors to the trans but will have to check
Old 01-20-2009 | 03:35 PM
bump for the day...
Old 01-25-2009 | 06:39 PM
bumity bump
Old 02-07-2009 | 01:00 AM
anyone...I thought for sure there would be a few interested people. I can part out.
Old 04-13-2009 | 11:49 AM
fastcamz28's Avatar
Is the shift plate for an A4? If so, how much do you want for it? I only need the shift indicator (small plastic part that is under the shift plate and attaches to the shifter leaves).
Thanks!
Mike
10-31-2016 11:09 AM
novaiiman
05-15-2016 11:36 AM
Queens94z28
12-20-2014 09:11 PM
BIGCOWL-IMP
12-19-2014 06:59 AM
Quick Reply: A4 conversion parts
