What other V6s are in the same engine family?
Old Feb 12, 2009 | 08:02 PM
AdioSS's Avatar
West South Central Moderator
Question What other V6s are in the same engine family?
Current domestic GM V6 engine displacement ranges from the Saab/Holden 2.8L Turbo up to the old 4.3L Small Block. Obviously the 4.3L is the only V6 in that family, but is the 2.8L related to anything else we have? Aren't the 3.5L and 3.9L in the same family? The Buick 3.8L is obvious. Are the 3.6L engines related to any other engines?
Old Feb 14, 2009 | 11:50 PM
Chevy Ryan's Avatar
"High Value" OHV V-6: 2.8L, 3.1L, 3.4L, 3.5L, 3.9L, all 60 degree bank with firing order 1-2-3-4-5-6
"High Feature" DOHC V-6: 2.8L, 2.8L DI turbo, 3.0L DI, 3.6L, 3.6L DI, all 60 dergree bank with firing order 1-2-3-4-5-6
3.8L Buick V-6
4.3L V-6, 350 with 2 cylinders chopped off
3.4L DOHC V-6 (1990s) "High Value" V-6 family with DOHC heads
3.5L Oldsmobile V-6 "Shortstar", Northstar with 2 cylinders chopped off
The 4.6L Northstar was roughly based on morphing the 3.4L DOHC V-6 into a V-8
I think this covers most of them.
Old Feb 16, 2009 | 03:26 PM
AdioSS's Avatar
3.8L Buick V-6
So the High Feature family includes the LP9, LLY, LY7, and whatever the 3.0L DI turns out to be called.
I'm surprised that the LP9 isn't more powerful. It should be making closer to, or over, 350hp instead of only 280. Maybe it uses less boost than the LNF? If the LP9 made the same specific output as the LNF or at least close, then it would be a great engine for the Camaro.
Old Feb 17, 2009 | 10:52 AM
Chevy Ryan's Avatar
Maybe the vehicle application calls for an emphasis on fuel economy over all-out power??
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
GhostZ28
Dec 7, 2014 11:53 PM
Hoodshaker
Aug 27, 2002 02:32 PM
