shop full of 93-02 F-body parts FS in DFW
Old 02-22-2009, 05:23 PM
STS95T/A's Avatar
here is a list of everything i can think of
i have many many more parts, so if there is anything else you need for a 93-02 f-body feel free to shoot me a pm
LS1 dual fan assembly-$80
LT1 dual fan assembly-$70
00+ LS1 manual radiator-$50
LS1 a/c condinser-$20
LT1 a/c condinser-$20
93-94 V6 single fan assembly-$40
washer fluid resivor with pump-$10
LS1 front brake conversion for 93-97 f-body (includes calipers, spindles, hubs, rotors, and all in between hardwear off a 99 camaro z28)-$175
LS1 front calipers-$100 pair
LS1 rear calipers-$80 pair
LS1 rear backing plates-$60
LS1 brake master cly with resivor-$20
LT1 brake master cyl with resivor-$10
non-ram air LS1 radiator shroud-$25
98-02 firebird or t/a headlight control module-$25
93-97 firebird or t/a headlight control module-$20
shock sensor-$10
LT1 under hood fuse/relay cover (with screw)-$10
LS1 under hood fuse/relay covers-$20 pair
camaro salad shooter center caps-$5 each
camaro salad shooter rims-$20 each
pontiac firebird 5 star 16in rims (95-99 style, they are not chrome)-$25 each
rear axil rubber bump stops-$15 pair
drivers and passenger camaro electric side mirrors in black-$25 each
passenger electric camaro side mirror in primer-$20
passenger electric firebird mirror in white, teal, or red-$25 each
tinted (95-02 style) t-tops-$80 each complete
t-top holders (in trunk) in charcole or ebony-$25 pair
t-top divider (on roof)-$10
t-top mounting brackets with hardwear-$10 set of 4
t-top weather stripping (the part that is attached to the car)-$25 pair
LS1 power steering rack-$60
LS1 steering rack coupler-$20
93-96 camaro fuse cover on dash-$10
93-02 firebird and 97-02 camaro fuse covers in charcole or ebony-$10 each
LS1 ABS control module 3 channel or 4 channel-$25 each
aluminum driveshaft-$100
96 M6 LT1 pcm-$50
95 A4 LT1 pcm-$50
94 M6 jet performance chip-$25
97-02 camaro radio bezel in charcole-$25
93-02 firebird or t/a radio bezel in charcole or ebony-$10
94-96 trans am / formula gauge clusters with 99k miles-$40 106k miles-$35 118k miles-$30 and 150k miles-$25
94-96 camaro z28 or ss gauge clusters with 129k miles-$30 173k miles-$25 and 306k miles-$20
00 trans am gaige cluster with 81k miles-$50 and 90k miles-$45
monsoon factory amp (mounts in spart tire well)-$20
97-02 camaro monsoon cd player-$60
98-02 hvac controls-$20
806 casting LS1 heads-$75 pair
93-97 passenger airbag-$20
98-02 passenger airbag-$25
95-99 firebird/trans am drivers airbag in gray-$40
00+ firebird/trans am dirvers airbag in ebony-$60
00 trans am airbag sensor-$20
LS1 complete gas tank with fuel sending unit-$80
LS1 gas tank without fuel sending unit-$25
LS1 e-brake cables (set of 3)-$30
LT1 e0brake cables (set of 3)-$30
A4 pedal assembly-$25
LS1 M6 pedal assembly with all sensors/pigtails-$60
93-96 camaro dash (main dash not upper dash pad)-$60
LS1 factory k-member-$50 (pick up only)
LT1 factory k-member-$40 (pick up only)
camaro tail light panel in red, maroon, blue, white, and blue with black stripes-$30 each
93 LT1 intake-$40
93 LT1 throttle body-$25
94-97 LT1 intake-$40
94-97 LT1 throttle body-$25
374 casting LT1 aluminum heads-$150 pair
LT1 ICM/coil assembly-$25
95 LT1 timing cover-$50
94 LT1 timing cover-$40
LT1 H2O pump-$30
LT1 accessory bracket-$25
94-97 LT1 fuel lines-$30 set
stock rear LCA's-$10 each
stock PHB-$20
stock torque arm-$20
upper front a-arms-$10 each
lower fornt a-arms-$15 each
LT1 rear brake calipers-$40 each or $70 pair
coolent resivor with good battery tray-$25
93-97 camaro complete headlight bar-$80
93-97 firebird headligh bar-$50
LT1 oil pan-$20
00 T/A cruse control module/cable-$30
T/A hatch struts-$25 pair
formula/camaro z28 hatch struts-$20 pair
dual horn assembly-$20
firebird/trans am circle vents in gray-$5 each
93-02 firebird/trans am tail light harness-$20
98-02 firebird/trans am window/lock/mirror controls in ebony-$40 pair
93-96 camaro hvac controls-$20
93-96 camaro headlight controls-$20
93-02 firebird/trans am headlight control panel-$20
98 LS1 fuel injectors (stock)-$30
all prices are obo and without shipping
i'm located in mansfield tx 76063
pm me if interested in anything
my paypal is f-bodyparts@hotmail.com
thanks
robbie
STS95T/A is offline
Old 02-23-2009, 01:04 PM
ulakovic22's Avatar
oil pan
94-97 manifold
T/A Hatch struts
PM with price
Thanks!
Edit: Also do you have any good tan/beige leather front seats for a Camaro?
ulakovic22 is offline
Old 02-23-2009, 03:50 PM
STS95T/A's Avatar
pm sent
sorry but no tan leather front seats
thanks
robbie
STS95T/A is offline
Old 02-24-2009, 11:04 AM
95GRNZ's Avatar
Robbie,
Would you happen to have ebony leather passenger side front seat from a 93-96 TA? Preferrably in good shape, too.
95GRNZ is offline
Old 02-26-2009, 07:42 AM
Projectcam94's Avatar
Im looking for a Radiator lower air dam . For my 95z28 . Mine broke where the screws go when i took it off. If you have one how much shipped to 78501?
Im also looking for this piece it goes under the bumper
Projectcam94 is offline
Old 02-26-2009, 09:00 AM
TonyC's Avatar
Robbie,
Mitch from FRRAX referred me to your post. I'm looking for the fuel pump and fuel level sending unit wiring harnesses for an LS1 car with plastic tank. Do you have these?
Thanks,
Tony
TonyC is offline
Old 02-27-2009, 07:27 PM
Glenn98ZM6's Avatar
Robbie - any V-6 motors?
Glenn98ZM6 is offline
Old 02-28-2009, 05:09 PM
4DRSS's Avatar
Any 94-97 LT1 fuel rails?
4DRSS is offline
Old 02-28-2009, 05:49 PM
Scotts94z28's Avatar
Would the hatch struts work on a camaro?
Scotts94z28 is offline
Old 03-01-2009, 10:36 PM
STS95T/A's Avatar
pm sent
sorry but no running V6's. i do have one with a blown headgasket out of a 99 camaro that i can do $200 for complete
thanks
robbie
STS95T/A is offline
Old 03-02-2009, 08:03 PM
STS95T/A's Avatar
pm sent
thanks
robbie
STS95T/A is offline
Old 03-02-2009, 08:40 PM
Old 03-02-2009, 10:17 PM
STS95T/A's Avatar
sorry i thought i sent you a pm
i could not find one in good condition
thanks
robbie
STS95T/A is offline
Old 03-12-2009, 05:08 AM
94307's Avatar
Need a/c hardline from dryer to a/c condesor. You know, the one that breaks from doing one too many cam swaps
94307 is offline
Old 03-16-2009, 09:21 AM
STS95T/A's Avatar
if you still need one i have a box of them
$5 picked up
pm me if interested
thanks
robbie
STS95T/A is offline
Quick Reply: shop full of 93-02 F-body parts FS in DFW
