Need Help!!! Lights won't come on.
Old Apr 22, 2009 | 08:15 PM
Hood_Lum's Avatar
I can't drive at night because the tail lights, dash lights, fog lights are all out.
I checked the fuses and everything is good.
Before, I could play with the headlight switch and the radio display will go out but everything else would come back on. Now the radio display is on all the time but none of the other lights will come on. I swapped the headlight switch and the new switch did the same thing. I pulled the radio out but still no lights.
Any suggestions?
Old Apr 23, 2009 | 12:34 AM
Hal Fisher's Avatar
Check for all the voltages and grounds to the switch with a volt/ohm meter. Just keep checking further up the line till you find a common source. Maybe pick up a Hayes or a shop manual. I just went through a very tricky problem. One of my grounds would stick high then drop low after a few minutes. It was caused by a bad external fuel pump. Not sure I needed a full shop manual but they are excellent to have. You can get a good used one on ebay for like $40 shipped!
Hal
Old Nov 8, 2009 | 01:53 AM
Hood_Lum's Avatar
Problem turned out to be a bad headlight switch.
It all started with the light on the radio going out when the lights are one.
Probably had something to do with the dimmer wire.
Because of that I was constantly messing with the headlight switch which made it eventually go bad. Replaced the radio and headlight switch and everything is good.
Hope this helps someone in the future.
Old Nov 19, 2009 | 11:58 PM
mattoney01's Avatar
I'm having the same problem with my 96 z28. My head lights work but nothing else does. How much did you pay for a switch?
Old Nov 20, 2009 | 01:11 AM
Hood_Lum's Avatar
$10 off ebay
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
