My Tranny shifts like a girl
Old May 21, 2009 | 04:26 AM
rpepka's Avatar
I just recieved delivery of my new Camaro 2SS. I sold my 2005 GTO. I am used to a much firmer shift, the GTO would chrip the tires going to 2nd from the factory. What can I do to get the same result without voiding factory warrentee?
Old May 21, 2009 | 06:42 AM
JasonD's Avatar
Admin Emeritus
Find a tuner that can firm up the shift points? Give Vector Motorsports a call, see if they can straighten you out and tell them that CamaroZ28.Com sent you.
Old May 21, 2009 | 04:26 PM
rpepka's Avatar
Thanks Jason
Old May 22, 2009 | 04:21 PM
z71collector's Avatar
I guess this car unlike the new GT500's doesn't have a traction control switch? I know if you go to the hennessey web site they have a utube link to the 1/4 run on their stockk SS and they do get a pronounced chirp out of second at about 55-60 mph. Although I would describe it better as a scratch rather then chirp. Those tires were nice and warm.
Old May 22, 2009 | 04:23 PM
BTW; Automatic trans?
Old May 24, 2009 | 08:55 AM
ImportedRoomate's Avatar
Yes its an auto. He'd be calling himself a girl if it was a manual.
Yes these cars do come with a traction control switch.
Old May 24, 2009 | 08:56 AM
JakeRobb's Avatar
Super Moderator
That was a manual trans.
Old May 24, 2009 | 09:57 AM
I should've assumed it was an auto. However assumptions are something I try to avoid. Thanks for clarifacation. And thank you for the info on a TCS. I am a little surprised that if the TCS was off that you don't get a bark out of 1st into 2nd. I bet that extra 26hp you waive for an auto,or the fuel economy improvement cost you the chirp?
Old May 24, 2009 | 10:08 AM
You're doing it again...
If the traction control is off its just a case of very soft shifting.
Old May 24, 2009 | 11:22 AM
JakeRobb's Avatar
Super Moderator
Thanks to VVT, the L99 has a wider powerband with better midrange power compared to the LS3. All other things being equal (i.e., if you swapped a TR6060 into an L99 car), it should be better at chirping the tires.
Old May 24, 2009 | 08:55 PM
Thanks again foe the REschooling!
Old May 28, 2009 | 06:22 AM
rpepka's Avatar
Could be, but my GTO had only a 6.0 and it had a great firm shift!
Old May 30, 2009 | 01:50 PM
Big Als Z's Avatar
I didnt know that the L99 had VVT and AFM. I assume the LS3 does not have VVT?
Old May 31, 2009 | 08:13 AM
Correct. That's why the L99 gets better mileage then the LS3.
Old Jul 29, 2009 | 12:09 PM
Buckyinva's Avatar
What kind of mileage is the L99 actually getting. In my LS3 I can get about 28-29 on a highway at 70mph.
