2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Wheels] The Widest Rear Wheel...
Old May 21, 2009 | 01:33 PM
RKHiPerformance's Avatar
Does anyone have any info on how much wheel and tire can be stuffed under the rear of the new Camaro?
I'd like to swap the tall & skinny OEM wheels for something a bit more steamrollerish.
Thanks,
Rick
Old May 21, 2009 | 01:54 PM
JasonD's Avatar
Admin Emeritus
According to Pedders, 12" on the rear.
https://www.camaroz28.com/forums/sho...d.php?t=683883
(See post #15)
That steamrollerish enough for ya?
Old May 21, 2009 | 09:56 PM
VChula's Avatar
For those of us who like to have the same wheel/tire set on all four corners, does anyone know if there will be issues if the the wider RS rear wheels are also installed on the front?
Old May 22, 2009 | 07:00 AM
2010_5thgen's Avatar
are you wantingthat so you can rotate the tires?
Old May 22, 2009 | 07:15 AM
JeremyNYR's Avatar
Originally Posted by RKHiPerformance
I'd like to swap the tall & skinny OEM wheels for ...
Wow, I didn't think these OEM wheels would ever be called skinny. It's not like the old days when they were 6 or 7 inches wide!
Old May 22, 2009 | 12:25 PM
JasonD's Avatar
Admin Emeritus
Pete also said that he believes 11" wide can go on the front (), if that helps.
Old May 24, 2009 | 05:41 AM
kookamunga's Avatar
for autox duty it would be the ay to go as steering is everything.
took a tpe measure to one and it seemed to have less fender clearance than the 4th gens which run 315/35/17's all the way around to be competitive. not sure if there is an equivelent race tire in the diameters required on the new 5th gen
Old May 24, 2009 | 02:34 PM
jcamere94z28's Avatar
12 inchers???? wow.
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
mongoose=
Mar 22, 2015 07:22 AM
cristian1311
Mar 4, 2015 04:45 PM
