Wrbate
Old Jul 29, 2009 | 07:20 PM
WRBATE's Avatar
Wrbate
Can anyone tell me what to do about the oscilation problems that are present in the 2010 SS Camaro's while driving at low speed. I think the problem stems from the function that tells the engine to run on 4,6,or8 cylinders?
Old Jul 29, 2009 | 07:32 PM
JasonD's Avatar
Admin Emeritus
Hello, moved to the right forum (I think).
What do you mean..."oscillation" problems? Are you experiencing something weird when the AFM kicks on?
Old Jul 29, 2009 | 07:33 PM
JakeRobb's Avatar
Super Moderator
The engine only runs in 4- or 8-cylinder mode. There is no 6-cylinder mode. The function you're referring to is called Active Fuel Management (AFM).
I'm not aware of any oscillation problems with the 2010 SS, AFM-related or otherwise. Can you describe the oscillation in more detail?
Old Jul 29, 2009 | 10:06 PM
wacker's Avatar
My auto does vary the rpm slightly when it goes into 4 cylinder mode. The camaro is not as seamless as other AFM vehicles I have driven, probably do to the immense power. It is much more noticeable with an aftermarket exhaust, you can actually hear the change in engine tone. You would think something was wrong if you did not know the vehicle was supposed to do it. My guess is this is why they made the stock exhaust soooo quiet.
Old Jul 30, 2009 | 03:52 PM
SSCamaro99_3's Avatar
Considering only 4 pistons are firing instead of 8, I would expect a change of tone.
