2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Wheels] Need more info for wheels
Old Nov 18, 2009 | 01:08 PM
racingracing's Avatar
Hi guys, I just joined the club I got a LT with RS package, and are about to purchase some 18" winter wheels package. I've done a lot of google and search on our site, but there still some info that I'm missing and hope you guys would know:
Lug nut size: 14x1.5mm?? (from what I found on McGuard site)
Hub Size: ?? (someone said 67.1mm?)
Lug nut seat: I believe conical?
Hex size: 22mm (from lot of place that I found)
If I got this info, I may see if I have any previous lug nuts that I have from other cars... to save some money
Thanks for any info in advance!
Old Nov 18, 2009 | 06:08 PM
sorry I meant to say "Need" more info for wheels on the topic, don't know why I missed the "Ne" there and I couldn't change it now :P
Old Nov 19, 2009 | 06:25 PM
JasonD's Avatar
Admin Emeritus
What wheels are you getting? They may require different lugs than what the factory wheels require.
Fixed the title.
Old Nov 20, 2009 | 07:59 AM
Thanks for fixing the title Jason.
From what I've found so far:
Hub Size: 67.1mm
Stock Lug nut seat: conical
Hex size: 22mm
Old Dec 1, 2009 | 05:13 AM
What Jason is explaining is that aftermarket wheels may not use the same type of lug nuts as the factory wheel. Yes, you have to match the thread pattern
(diameter and pitch), but not all wheels use a conical lug seat. Some drag wheels, for example, require shank type lugs. The seat type is determined by the wheels, not the car you are putting them on.
Old Dec 1, 2009 | 06:59 AM
JasonD's Avatar
Admin Emeritus
Thanks for clarifying, Fred! That is what I was referring to.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dpw21562
Jan 23, 2015 04:58 PM
Jason Short
Jan 19, 2015 06:33 PM
bernie1951
Dec 10, 2014 10:03 AM
squarehead
Nov 21, 2014 08:02 PM
