2011 Convertibles: Camaro SS vs Mustang GT comparison
Found some comparison data from the 2011 convertibles with links from each test below:
2011 Camaro SS convertible 6 spd man:
0-60 mph 4.9 sec, 1/4 13.2 sec@109.2 mph
2011 Mustang GT convertible 6 spd man:
0-60 mph 5.3/5.0 sec w/1 foot roll out, 1/4 13.5 sec@105.4 mph
0-60 mph 4.7 sec, 1/4 13.2 sec@108 mph
It's interesting to see from motor trends early tester how the camaro and the mustang convertibles stack up to each other. I know these are not test's that were done on the same track or on the same day but it's arguable that the camaro test had a much worse test day due to the So-Cal rainy weather during this article. Just take it for what it's worth until a side by side test between the two comes out.
2011 Chevrolet Camaro SS Convertible manual by Motor Trend
POWERTRAIN/CHASSIS
DRIVETRAIN LAYOUT Front engine, RWD
ENGINE TYPE 90-deg V-8, aluminum block/heads
VALVETRAIN OHV, 2 valves/cyl
DISPLACEMENT 376.1 cu in/6162 cc
COMPRESSION RATIO 10.7:1
POWER (SAE NET) 426 hp @ 5900 rpm*
TORQUE (SAE NET) 420 lb-ft @ 4600 rpm*
REDLINE 6500 rpm
WEIGHT TO POWER 9.7 lb/hp
TRANSMISSION 6-speed manual
AXLE/FINAL-DRIVE RATIO 3.45:1/1.97:1
SUSPENSION, FRONT; REAR Struts, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
STEERING RATIO 16.1:1
TURNS LOCK-TO-LOCK 2.5
BRAKES, F;R 14.0-in vented disc; 14.4-in vented disc, ABS
WHEELS, F;R 8.0 x 20-in; 9.0 x 20-in, cast aluminum
TIRES, F;R 245/40ZR20 103Y; 275/40ZR20 106Y Pirelli PZero
DIMENSIONS
WHEELBASE 112.3 in
TRACK, F/R 63.7/63.7 in
LENGTH x WIDTH x HEIGHT 190.4 x 75.5 x 54.7 in
TURNING CIRCLE 37.7 ft
CURB WEIGHT 4116 lb
WEIGHT DIST, F/R 51/49%
SEATING CAPACITY 4
HEADROOM, F/R 37.8/35.7 in
LEGROOM, F/R 42.4/30.0 in
SHOULDER ROOM, F/R 56.8/42.4 in
CARGO VOLUME (TOP UP/DN) 10.2/7.9 cu ft
TEST DATA
ACCELERATION TO MPH
0-30 2.0 sec
0-40 2.8
0-50 3.7
0-60 4.9
0-70 6
0-80 7.7
0-90 9.3
0-100 11.2
PASSING, 45-65 MPH 2.2
QUARTER MILE 13.2 sec @ 109.2 mph
BRAKING, 60-0 MPH 107 ft
LATERAL ACCELERATION 0.89 g (avg)
MT FIGURE EIGHT 25.9 sec @ 0.61 g (avg)
TOP-GEAR REVS @ 60 MPH 1300 rpm
CONSUMER INFO
BASE PRICE $37,500
PRICE AS TESTED $42,280
STABILITY/TRACTION CONTROL Yes/yes
AIRBAGS Dual front, front side
BASIC WARRANTY 3 yrs/36,000 miles
POWERTRAIN WARRANTY 5 yrs/100,000 miles
ROADSIDE ASSISTANCE 5 yrs/100,000 miles
FUEL CAPACITY 18.8 gal
EPA CITY/HWY ECON 16/24 mpg
ENERGY CONS., CITY/HWY 211/140 kW-hrs/100 miles
CO2 EMISSIONS 1.03 lb/mile
RECOMMENDED FUEL Unleaded premium
*SAE CERTIFIED
Read more: http://www.motortrend.com/roadtests/...#ixzz1ArmaiPAa
Compared to the 2011 Mustang GT convertible 5.0 manual by Inside Lines from Edmunds:
Vehicle: 2011 Ford Mustang GT Convertible
Odometer: 1,689.2
Date: 10/16/10
Driver: Chris Walton
Price: $41,705
Specifications:
Drive Type: Rear-wheel drive
Transmission Type: Six-speed manual
Engine Type: 5.0-liter DOHC four valves per cylinder, variable intake, V8
Displacement (cc/cu-in): 4,995/302
Redline (rpm): 7,000
Horsepower (hp @ rpm): 412 @ 6,500
Torque (lb-ft @ rpm): 390 @ 4,250
Brake Type (front): 14-inch ventilated discs with four-piston fixed calipers
Brake Type (rear): 11.8-inch ventilated disc with 2-piston sliding calipers
Steering System: Electric-assist power steering
Suspension Type (front): MacPherson strut, stabilizer bar
Suspension Type (rear): Solid live axle, limited slip
Tire Size (front): P255/40R19 96W
Tire Size (rear): P255/40R19 96W
Tire Brand: Goodyear
Tire Model: Eagle F1 Supercar
Tire Type: Summer Performance
Wheel size: 19-by-9.0 inches front and rear
Wheel material (front/rear): Aluminum
As tested Curb Weight (lb): 3,726
Test Results:
0-30 (sec): 2.3
0-45 (sec): 3.7
0-60 (sec): 5.3
0-75 (sec): 7.5
1/4-Mile (sec @ mph): 13.5 @ 105.4
0-60 with 1-ft Rollout (sec): 5.0
30-0 (ft): 29
60-0 (ft): 116
Slalom (mph): 68.0 ( 65.5 w/traction control on)
Skid Pad Lateral acceleration (g): 0.88 (0.88 w/traction control on)
Db @ Idle: 51
Db @ Full Throttle: 89.7
Db @ 70 mph Cruise: 74.3
http://blogs.insideline.com/straight...nvertible.html
Compared to the 2011 Mustang GT convertible 5.0 manual by Car & Driver:
VEHICLE TYPE: front-engine, rear-wheel-drive, 4-passenger, 2-door convertible
PRICE AS TESTED: $41,765 (base price: $35,495)
ENGINE TYPE: DOHC 32-valve V-8, aluminum block and heads, port fuel injection
Displacement: 302 cu in, 4951 cc
Power (SAE net): 412 bhp @ 6500 rpm
Torque (SAE net): 390 lb-ft @ 4250 rpm
TRANSMISSION: 6-speed manual
DIMENSIONS:
Wheelbase: 107.1 in Length: 188.1 in
Width: 73.9 in Height: 55.8 in
Curb weight: 3754 lb
C/D TEST RESULTS:
Zero to 60 mph: 4.7 sec
Zero to 100 mph: 11.4 sec
Zero to 140 mph: 24.6 sec
Street start, 5–60 mph: 5.0 sec
Standing ¼-mile: 13.2 sec @ 108 mph
Top speed (governor limited): 147 mph
Braking, 70–0 mph: 162 ft
Roadholding, 300-ft-dia skidpad: 0.88 g
FUEL ECONOMY:
EPA city/highway driving: 17/26 mpg
C/D observed: 15 mpg
http://www.caranddriver.com/reviews/...take_road_test
These times are almost identical to each other and really shows how the low end torque and grip from the camaro's chassis setup helps it even with a 300-400 lb. penalty in weight compared to the mustangs posted curb weight.
Great job as usual Camaro Team!!!
POWERTRAIN/CHASSIS
REDLINE 6500 rpm
DIMENSIONS
WHEELBASE 112.3 in
CURB WEIGHT 4116 lb
SEATING CAPACITY 4
TEST DATA
ACCELERATION TO MPH
0-30 2.0 sec
0-40 2.8
0-50 3.7
0-60 4.9
0-70 6
0-80 7.7
0-90 9.3
0-100 11.2
CONSUMER INFO
BASE PRICE $37,500
*SAE CERTIFIED
Odometer: 1,689.2
Date: 10/16/10
Price: $41,705
Specifications:
Test Results:
0-30 (sec): 2.3
0-45 (sec): 3.7
0-60 (sec): 5.3
0-75 (sec): 7.5
30-0 (ft): 29
60-0 (ft): 116
Db @ Idle: 51
DIMENSIONS:
C/D TEST RESULTS:
FUEL ECONOMY:
Re: 2011 Convertibles: Camaro SS vs Mustang GT comparison
Pretty close performance wise. While I know the GT convertible is lighther than the Camaro SS convertible, does it really only weigh 3726 lbs? That is quite a bit lighter than the 4116 lb Camaro.
Coming from a person who drove both cars back to back.......
The Mustang GT vert handled like a slush puppy compared to the Camaro SS vert. The chasis improvements Ford made to the GT coupe did not make it to the GT vert.
Faster in every way!
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=351&t ransactionid=1298380149-993272194&posted_by=terryj_camaroz28.com[/autostream]
How is it trolling if one car is faster than the other stock and people are just saying the facts? The Mustang is faster than the Camaro up til about 90 or so then the Camaro will overtake the Mustang. The 392 Challenger will overtake all of them up to it's 180mph top speed. Properly driven the Mustang is a bit faster in teh 1/4 mile than the SS after that the SS will be quicker.
ChrisFrez
01-11-2015 04:47 PM
NewsBot
12-30-2014 10:40 AM
ChrisFrez
12-15-2014 04:09 PM
ChrisFrez
12-07-2014 07:01 PM
NewsBot
12-03-2014 01:30 PM
