400-plus-hp, 6.0-liter V-8 or a 300-plus-hp,3.6-liter V-6
#31
Nope, I don't buy the percentage either. IMHO, a typical V8 will lose ~50 HP through a street-style manual transmission drivetrain -whether it is a stock 205 HP 5.0, or a stock 400 HP LS2. Perhaps a bit more with the higher HP, and a bit less with the lower HP, but not double/half.
is that why NASCAR runs rear diff coolers?
or why SB and BB powerboats run coolers on their outdrives?
Heat = parasitic power loss.
it is not static nor quite linear, but the percentage correction is far more accurate than the 50hp myth.
#33
OK let's see what we have again.
M6 LS2 dyno around 360RWHP(not 340 as I claimed earlier)
M6 LS3 dyno around 395RWHP
Now at a 15% loss
The LS3 is about 464 and the LS2 is about 424.
but look at what happens when we take a 10% loss.
The LS3 calculates out to 439 at the crank.
And the LS2 calculates out to 400 at the crank.
I think that perhaps the vette transaxle is even more efficient than the standard RWD layout.
the SAE certified numbers certainly match up at a 10% loss on the C6.
Which is perfectly fine by me.
Now at a 15% loss
#34
Just a WAG but it's somewhere north of 350hp. Not 350hp for 14sec like a dragstrip. But 350hp WOT for tens of minutes.
We've all driven 500+ miles somewhere at sometime. Who needed a rear diff cooler for that? No one because we're averaging 75mph not 185. Even if you drive your 600rwhp SC'ed Z28 cross country and you average 75mph, you're putting about 50-60hp into the drivetrain continuously.
#35
Bob
PS...SAE corrected LS2 GTOs dyno closer to 340 RWHP than to 360 RWHP. Perhaps Vettes are different - I haven't done that research.
#36
#37
Ok. I never said it was exact, but I do think the "~50 hp myth" is closer than an arbitrary "xx% myth". So you stick with your myth and I'll stick with mine.
Bob
Bob
I think the drivetrain losses through the vette are about 12.5%.
The vipers, from what I've seen (they've been certified as well) are closer to 10%.
The GT500 is closer to 14%.
this is just observation, i havent compiled enough statistics on the subject to say any of that as anywhere near fact. plus, you have to remember that even gear ratio's change measured output as well, so thats another wrench to throw in there.
#39
A good example someone brought up was taking a v8 powertrain that cosumed 75 hp through it's powertrain. What if a 75hp 4 banger was put in it's place? Would 0hp be recorded at the wheels? Probably unlikely. It might be worth a search, if you don't mind looking around for it. It was a really interesting and in depth thread. I would try to find it myself, but I don't think I will have the time this evening to do it. Hopeful it is on camaroz28.com. It could be on ls1tech.com, as they have an advanced tech section over there as well, and many of the posters over here post over there as well.
#40
And to throw another wrench in ALL of this % vs whatever idea....I've had 3 different transmission models in the same car (99 Cobra), and compared them with no engine changes or other chassis changes. The same dyno was used, and all were SAE corrected. The results are that a TKO/3550 took 13 more HP to turn than a T45, and the T45 took 4 more HP than a T5. I bet if I'd of done the same with a T56, it would have been more of a loss than the TKO.
Things that make you go hmmmmm.
#41
#42
That sounds like a reasonable conclusion to me. However, I would suggest that the drivetrain loss is largely due to the beefier driveline parts needed to handle the power - with perhaps some in extra heat.
#43
#44
and the LS3's have been in the 380's rwhp.
#45
The LS3 is underrated by nothing. It was SAE certified at 430 and 436hp depending on exhaust. That means every Corvette LS3 coming off the line is within 1% of that at the crank, regardless of transmission. If it was really making 470 that's what it would've been certified at. The SAE cerification process has put an end to underrating.
And where did you get 400rwhp from? Last I saw it was 370rwhp for an A6 and 385-390 for the M6. That gives them close to the same loss as a Z06, Viper, GT500 or even a GTO.
I've never heard of a good running LS1 putting 290 to the wheels either. My 01 M6 car put down 310 when it was new.
Good post. Agreed 100%
