Dimensions
Dimensions
I am ordering a new enclosed trailer and what to make sure that the 5th gen (along with the first 4 generations) will be able to fit correctly. In addition, I will have a door on the driver side of the trailer so you don't have to crawl out of the cars. I have looked at the spec sheet for the new car, but need some other dimensions that maybe someone on the site has. Here are some dimensions I would like to have:
1. Distance from either the front and rear wheel center line or to the back of the drivers side door.
2. Distance from either the front or back bumper cover to the back of the drivers side door.
3. Distance from the front bumper cover (the farthest forward point preferably) to the center line of front wheel.
4. Distance from back bumper cover to the center line of the rear wheel.
Additional question:
The "track" dimension, is that from outside edge to outside edge of the tire/wheel?
I also know that a lot of the above dimensions are pretty much the same, but the answer to just one or two would be helpful.
