DRL question
Old 08-27-2009 | 08:35 PM
VetteMark's Avatar
DRL question
I have a 2SS RS and I was wondering if anyone has figured out how to gain control of the DRL's so that they can be on all the time or turned on will in other Light Switch positions?
Old 08-27-2009 | 08:55 PM
JasonD's Avatar
Admin Emeritus
Good one. I find myself switching the halos on. I dig 'em.
Old 08-27-2009 | 09:34 PM
VetteMark's Avatar
Me too but I'd like the driving light look and think that it would be awesome with both Halo and DRL's on . . .
Some have mentioned a color diff between them but that can be corrected with a different Halogen bulb or HID's like they have done with the C6.
Old 08-28-2009 | 08:12 AM
2010_5thgen's Avatar
ive tried to figure it out but theres no way without cutting some wires im sure
Old 08-28-2009 | 08:59 AM
ImportedRoomate's Avatar
Your DRLs are on. They're your fog lights.
Old 08-28-2009 | 10:40 AM
VetteMark's Avatar
They go off as soon as your lights come on in Auto Mode or as soon as you move the switch off Auto Mode to Halo/Parking Mode or Full On Mode.
I'd like to be able to leave them on all the time or turn them on and off while in Halo/Parking Mode.
Old 08-28-2009 | 10:54 AM
i dont think it would be too hard to put a switch in if you know anything about wiring. find the day time running light wire and disconnect it and run a switch to it. then you should be able to run it whenever you want.
Old 08-28-2009 | 12:02 PM
guionM's Avatar
Can't you turn on the same lights as the DRL manually?
IE: the foglights?
Old 08-28-2009 | 12:57 PM
HTWLSS's Avatar
Disciple
The question is, why would you want to do that?
Why can't you use the **** on the dash to override?
Old 08-28-2009 | 01:31 PM
the running lights go off once the headlights or halos come on. there is no override for it.
Old 08-28-2009 | 08:32 PM
VetteMark's Avatar
Exacto . . . one of the penalties of the RS package.
I think that if you put a non RS switch in and run down the DLR wire, you should be able to splice a power wire from the switch to the DLR wire to override the DRL shut on Halo light up. Guess I'll have to investigate since noone else has tried . . .
Old 08-29-2009 | 11:58 AM
HTWLSS's Avatar
Disciple
That's not a penalty!
Driving with the halos, or as we call them, "the cool lights" by themselves, are what makes the car look so good.
Running two different kind of lights, the halos and fog/DRLs together = "not so cool".
Old 08-31-2009 | 04:52 PM
VetteMark's Avatar
True enough but the they are not brite enoughas it gets darker plus the "Cool Lights" get lost when the HID's come on.
Old 09-01-2009 | 08:11 AM
i found a HID kit for any kind of light. you could use it for the fog lights or running lights if you put them on a switch. it would make them look like the same brightness as the halo and HID lights. my buddy put a set on a lexus is250. it comes with a ballast for each light. he has it on the headlights and the fog lights. the head lights were bright as hell. then last night we put them on the fog lights. HOLLY $HIT!!! it was freaking bright! ony cost him about 60 a pair. the fog/ headlight combo is actually better than running the brights.
Old 09-01-2009 | 09:50 PM
VetteMark's Avatar
Common on the C6 also . . .
dluna333
15
03-13-2015 01:30 PM
jasonduaine
03-07-2015 10:44 AM
blac94Z
01-17-2015 12:03 AM
95z_28_camaro_4_Ivan
12-19-2014 09:48 PM
Hurin
12-13-2014 08:38 PM
