Early Camaro SS manual transmission failures reported, factory hold issued
Old 07-14-2009 | 01:57 AM
95redLT1's Avatar
http://www.autoblog.com/2009/07/13/b...ures-reported/
Sporadic reports have begun popping up in the Camaro5 forums about issues with V8-powered SS models equipped with the manual transmission. It seems that doing a hard launch or using the launch control system occasionally results in a broken output shaft, a serious failure that will most likely leave the car immobile and in need of repair. We spoke with General Motors spokesman Adam Dennison about the problem and, as this is being written, a factory hold has been put on deliveries of manual transmission V8 Camaros while Chevrolet engineering teams investigate the problem.
Based on the reports, the transmission issues may not be related to the launch control system as the failures seem to happen whether or not launch control is engaged. The Camaro SS uses the Tremec 6060 six-speed gearbox – the same transmission fitted to the Dodge Viper, Mustang GT500, Corvette Z06 and other performance cars – so this is likely a manufacturing issue with a batch of gearboxes.
Dennison told Autoblog that an engineering meeting is being held this evening to identify the cause and establish a timing for the fix – and a recall seems likely. In the meantime, if you have a manual model Camaro SS, you might want to go easy on the launches for now – and if you have one ordered, you'll have to wait a bit longer. Thanks to Bailey and Derrick for the tips!
Old 07-14-2009 | 02:33 AM
SSbaby's Avatar
Wow, that's not exactly great news.
I hope it's just a faulty part as the HSV Commodores (which use the TR6060) don't have that issue here despite being heavier cars than Camaro. No traction control option on M6 HSVs either.
Old 07-14-2009 | 04:57 AM
35thCamaroZ28's Avatar
Sssshhhhhh!!
Old 07-14-2009 | 07:42 AM
Outrun's Avatar
I didn't want to see that.
Old 07-14-2009 | 09:03 AM
seawolf06's Avatar
The one good thing GM had going for it....
Old 07-14-2009 | 09:26 AM
km9v's Avatar
Chevy needs to spin it: "The new camaro SS is so powerful, it breaks output shafts!!!"
Old 07-14-2009 | 09:51 AM
irocbsa's Avatar
Don't lose your head guys, the sky isn't falling. The issue will be fixed as quickly as possible I'm sure.
Old 07-14-2009 | 10:15 AM
Wild Willy's Avatar
As long as GM makes it right- maybe loaners for the customers whose cars are tied up in the shop-
"So powerful, it needs a titanium output shaft...."
Old 07-14-2009 | 10:31 AM
Vette Pro's Avatar
More confirmation on why I never buy the first model year of any car.. ... in two years they will have all the bugs worked out ...
Old 07-14-2009 | 10:39 AM
seawolf06's Avatar
And maybe HUD and a new engine.
Old 07-14-2009 | 12:45 PM
STOCK1SC's Avatar
And 3:73 gears!
Old 07-14-2009 | 01:45 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by STOCK1SC
And 3:73 gears!
NOW THAT'S SOME GEAR!
Oh, did you mean 3.73:1? Oh.
Old 07-14-2009 | 02:04 PM
99SilverSS's Avatar
Although the Camaro SS uses the same kind of Tremec TR6060 as the Viper/GT500/Z06/ZR1/CTS-V it's certainly not built to the same spec internally as the higher hp and more expensive vehicles.
I hope it's just a bad batch of defective parts because if it's something else then it's going to be costly to GM and Tremec.
Old 07-14-2009 | 02:08 PM
boomer78's Avatar
That'd make me feel OH SO BETTER after being stranded and having to call roadside assistance.
Old 07-14-2009 | 03:02 PM
STOCK1SC's Avatar
Now seriously how often do you see people on the boards write out the whole gear? 4.10 gears or 4.10.1 gears? I'd say never. 4.10 would be awesome as an option but we'll be lucky to even get 3.73's. Ok, I see what I did now and edited it.
