An "ender" to the "the fbody has never had more power than the top vette" question
#16
Re: An "ender" to the "the fbody has never had more power than the top vette" question
I think it would be hard to find the info on the ZL1 Vette since only two were ever made. So no comparo between the two ZL1s. Both cars however were just incredible for the time they came out and would still kick so much a** at the tracks.
#17
Originally Posted by CLEAN
The ZL1 Camaro was faster than a ZL1 Vette? And I would think an L-88 vette would still take down a ZL1 Camaro that year, only difference was an aluminum block vs iron as I recall, and the Camaro was a good bit heavier than a Vette to start with. That would be something to see!
#18
What was actually different in the ZL1 and L88 motors, besides obviously one being aluminum and one being iron?
#19
The ZL1 block was like an aluminum L88 but better. It had thicker walls, higher domed pistons, more compression, better heads, different cam made to rev, etc. It was improved all around and was most definetly not rated correctly. Neither was the L88 but they didn't do what ZL1's could, close but not quite.
#20
#21
#22
Since emissions were required, when has a camaro had more more horse power than the base vette.
Maybe the market has changed enough in the camaro's absense for GM to justify making a GT500 competitor. I hope that's the case but I'm not holding my breath.
Oh, to answer my question - only two years come to mind, both times camaro had the exact same engine it was rated the same or 5hp higher (thx SLP).
Gtpguy
01-26-2015 05:50 PM
ChrisFrez
12-07-2014 07:01 PM
