GMs camaro problem
GMs camaro problem
GMs big problem with a new camaro is CAFE. GM can not build any more cars which will hurt the CAFE because they need to sell big SUVs that also hurt their CAFE but adds profit to their bottom line. fords mustangs do not hurt ford that much because they sell a lot of V-6 ones but you can bet that if GM comes out with a camaro most all buyers will want the LS-2 or bigger engine because to most people the camaro is the poor mans corvette
Re: GMs camaro problem
Originally Posted by NewbieWar
lets hope they dont put a v6 in the base camaro...
I would have purchased one in a heartbeat.
That is not even a issue where the Camaro is concerned . The LSx engines deliver in some cases better fuel mileage than 6 cyl. cars they sell in huge volumes . GM is not currently hurting on the CAFE standards
Metal - Which car was that , I'm having trouble remebering . There was a 97 red ram air Formula , and a 97 black ram air TA . One had the S/C 3800 and one had the mini-cube LT1 . I think it was the Formy that had the S/C 3800 . Couple of cool one off oddballs in Pontiac history , thats for sure .
Why? The car will NOT sell with a V8 alone. Just look at the GTO.
4L Eaton V6 please.
Yes...
The GTO sells fine. Its not ment to blow through any sales records, unless you look at how many Monaro's are actualy made for Aussie consuption compared to GTO's for America....then you could see that Holden imports about 3 times the amount of GTO's here then it sells in Down Under.
3.9 VVt V6 making 250ish hp, or if its budgetable, do the 3.6 DOHC with D/I and make 270hp with regular octane. I would be very upset if the V6 has to take high octane, and so will others.
Originally Posted by johnsocal
While all of us will buy v8's, GM will most likely sell more v6's to the masses like Ford's Stang.
Let the masses buy v6s while enthusiasts buy v8's
Originally Posted by Big Als Z
Yes...
The Mustang sells 100K units a year but the GTO can barely sell 12K.
Originally Posted by UtOhCop
If it sells so great. Why did GM cut production for 05? Exactly.
