Need to charge my Battery . . .
Old 12-29-2009 | 08:50 PM
VetteMark's Avatar
Hi All,
I need to charge my Battery before it goes completely dead, where should I connect the charger? The same place I would connect Jumpers?
Old 12-29-2009 | 09:02 PM
JasonD's Avatar
Admin Emeritus
Shoot...I don't have my manual handy. Did you check that or was it no help? I'd kinda like to know as well.
Old 12-29-2009 | 09:20 PM
VetteMark's Avatar
yup, used my PDF Manual to check . . . no mention of charging, just jumping and they recommend the terminals under the hood. They do suggest disconnecting the negative if stored for long periods but I try to avoid that with all the 9 cars currently in storage.
Old 12-29-2009 | 09:52 PM
JasonD's Avatar
Admin Emeritus
Yes, I think that is the correct way to do it. If it works for jump starting...I believe it should work for trickle charging.
Old 12-30-2009 | 08:31 AM
2010_5thgen's Avatar
i put a charger on my car for the winter. the charger i actually used had a set of connecting wires, with the easy disconnect, to go onto the battery. i connected them to the small nuts on the battery and ran the wire through a hole in the bottom of the trunk. it looked like it was meant to be used for this.
Formula Steve
09-19-2023 09:31 AM
68camaroboltz
10-05-2015 02:46 PM
jackpawt883
09-10-2015 09:53 PM
WPHIG2
08-27-2015 07:37 AM
