Whipple install
Whipple install
I'm having a Whipple Installed on my 2011 SS. It's a LS3, I had dynatech L/Ts and high flow cats in already. Flowmaster A.T. cat back. G5CR stage 2 intake, and ported throttle body. On two different dyno I put down 402RWHP.
Now I'm having the Whipple installed, lingenfelter dual fuel pumps, new set of Nitto NT05s, Pfadt trailing arms, and the rest of the Pedders bushings I didn't do on a previous install. Hope you guys like.
Re: Whipple install
Awesome! Be careful with those NT05s...they are awesome for dry performance, but when the surface is cold or damp...and the boost creeps up...watch out! I know from experience.
Keep us posted on how things go from here!
Thanks,the car is not my DD, and it's summer time in SoCal now.
Re: Whipple install
Were the fuel pumps needed with the supercharger?
NICE! What made you decide which components to go with Pfadt and which to go with Pedders?
Just curious...
Also is that the blue bowtie from SLP?
Dual fuel pump are better than BAPs. I don't want to run lean.
I started with pfadt suspension parts for springs and sways. Pedders as all the bushing was recommend from the shop doing the install.
And i don't have a blue bowtie from SLP.
Thanks Reaper! It should top off at 10PSI. Using siemens 63lbs hour injectors. I just want to break 600RWHP.
