Any 5th gen free mods?
Old 07-15-2011 | 06:32 AM
  #16
2010_5thgen's Avatar
Re: Any 5th gen free mods?
ordered my ADM air scoop yesterday from auto agenda! hope its as easy to install as you say mucker.
Old 07-22-2011 | 08:39 AM
  #17
adm air scoop came in! ill be putting it in tonight hopefully.
Old 07-22-2011 | 08:43 AM
  #18
Mucker15's Avatar
its not bad to install good luck
Old 07-25-2011 | 01:21 PM
  #19
installed my air scoop saturday.... not too bad. wish i had a better cutoff tool. i used a box cutter...... and the 6mm bolt that was supplied, was a 10mm....other than that...everything went smoothly. my washerfluid resevoir was completely full. weighed alot. and surprisingly, you can notice it when its out. not sure why or how,...but i did.
Old 09-16-2011 | 02:13 PM
  #20
colin911's Avatar
Originally Posted by 97QuasarBlue3.8
Except for the #5 and #20 fuse-pull for the SS, to reset the fuel map if you haven't done so already.
If you didn't know about this one...cheap/regular gas used when the dealer fills up the car before delivery causes the car to adjust the fuel map. The programming in the ECM is only uni-directional. Once the fuel map has been adjusted for cheap gas, it can't reset if the octane goes back up. I burned through the first tank of 'dealer gas', filled up with premium, and then reset the ECM about 50 miles later. Nice difference!
Do other new performance cars do this? It seems ridiculous that this car (or any car for that matter) would be programmed that way.
Old 09-16-2011 | 02:18 PM
  #21
JasonD's Avatar
Admin Emeritus
It may be a break-in or CAFE regulation function.
Old 10-10-2012 | 09:26 PM
  #22
nicecamaro's Avatar
Have you checked out an oil catch can? This replaces the pcv line that goes into the intake, suppose to catch oil fumes before going into intake making a cleaner burn.
Old 10-15-2012 | 08:05 PM
  #23
7777 OUTLAW's Avatar
when taking out the washer fluied bottle what u do with wire sensior ? will it read like on dash to check it or low ?
Old 10-18-2012 | 05:57 AM
  #24
well not much feed back but done mow and mo code
Old 10-18-2012 | 05:13 PM
  #25
Video's Avatar
I'm not sure how the newer Camaro's work for emissions but I'm sure theres plenty you can remove like any EVAP solenoids or EGR valves etc.
Also theres more than just adding power, im sure theres TONS you can remove to lighten up your car. Sound deadening under the carpet, rear speakers if you have any, spare tire, rear seats, etc. depends on your goal for you car. If it was my car I wouldnt even touch it. It has too much value and the more you mess with it the more the value drops.
But if you plan on keeping it forever, go ahead and start removing some useless crap but I would still keep it in storage in case you ever decide to sell it.
As far as the washer fluid...thats nuts you have a sensor...im stuck in the 90's still. Sounds annoying haha. Im sure you can trick the sensor or unplug it and delete it from the computer somehow.
Old 10-19-2012 | 07:36 AM
  #26
man i just read my post an i must have been tired .lol... i removed/unpluged the water bottle and sensior nevet cut on . I did 63series K&N ,diablo in tune and cut mufflers off and car sound GREAT ..
alex5366
03-08-2015 11:32 AM
Fusion93Z
09-10-2002 06:46 PM
Thebeast431
08-25-2002 05:06 PM
GC456
08-08-2002 11:53 PM
Thebeast431
08-08-2002 01:39 PM
Quick Reply: Any 5th gen free mods?
