Why not a turbo V6?
Old 06-18-2008 | 10:38 AM
Gripenfelter's Avatar
Why not a turbo V6?
I've been joking around for a while now about a "Maximum Bob" turbo V6 but I think with the current gas prices a turbo V6 could actually attract a lot of buyers.
Base 300 hp DI V6 and a 400+ hp turbo V6.
Old 06-18-2008 | 12:47 PM
Dragoneye's Avatar
I'd buy it.
Old 06-18-2008 | 12:52 PM
JakeRobb's Avatar
Super Moderator
I already own a turbo V6. Love it. The turbo V6 F-body has been done ('89 Turbo TA), and was/is awesome. GM should do it again!
Having said that, a naturally aspirated V8 must be on the option list.
Old 06-18-2008 | 02:18 PM
STOCK1SC's Avatar
Given the choice between a 400hp turbo 6 and a 400 hp NA V8, I'll take the turbo 6, it will be faster and get better mileage(not much but maybe 1-2) and be easy to mod granted it isn't made out of glass. Not to mention it will probably be lighter, again not by much but 100lb's is possible.
Old 06-18-2008 | 02:45 PM
metal's Avatar
SEMA Media Team
I have two Turbo6 F-Bodies (89 Turbo T/A and a 92 Z28 I converted) you know I'd be all over it.
A GM ad with a GN fading into a 5th gen with the tag line like "We did it again..." would be great!
Old 06-18-2008 | 05:02 PM
mike24's Avatar
Put me down for one
Old 06-23-2008 | 02:13 PM
Aaron91RS's Avatar
turbo cars don't really get any better mpg then there couterpart NA V8 cars.
Therefore I can't see a reason for GM to do it.
Old 06-23-2008 | 02:33 PM
JakeRobb's Avatar
Super Moderator
Why would it be faster?
Old 06-23-2008 | 02:41 PM
Jason Dove's Avatar
Because of the blow off valve noise.
Old 06-23-2008 | 07:25 PM
Grape Ape's Avatar
I don’t think it will be meaningfully lighter (or heavier), although the weight should be a little farther back.
But the modern Turbo, DI, VVT engines (LNF and the 6 in the 335) have flatter torque curves than anything I’ve ever seen attributed to a NA V8.
Old 06-24-2008 | 07:29 AM
STOCK1SC's Avatar
More torque than a NA V8 can make. GN's made more torque with 3.8l than Corvette's did with 5.7l.
Old 06-24-2008 | 03:37 PM
Grape Ape's Avatar
Sky Redline (2.0 with DI and a turbo): 19/28 MPG & 260hp
Base Sky (2.4 NA with port injection): 19/25 MPG & 173hp
I can only assume that a Sky with a LY7 (3.6 port injection V6) would get worse mileage than either of the fours do to parasitic losses.
I think that a twin turbo V6 Camaro could actually return better mileage than the base (NA) V6.
Old 06-24-2008 | 08:29 PM
81Z28355's Avatar
Why would it need to be a twin turbo? The Grand Nationals did'nt seem to need more than one 20 years ago to beat up on most other cars on the road.
Old 06-25-2008 | 03:19 PM
Grape Ape's Avatar
It wouldn't need to have two turbos but two small turbos would spool-up faster than one bigger one. That probably wouldn't matter to the drag guys, but I want a daily driver.
Old 06-25-2008 | 03:28 PM
Dragoneye's Avatar
Assuming the base NA V6 is the Direct Injected one....would it? Problem is, GM doesn't have a NA Direct Injected I-4 from which to judge.
I guess my question is, does a modest (OEM) Turbocharger always increase fuel economy?
Quick Reply: Why not a turbo V6?
