[Tires] RS Camaro 2010 tires
Re: RS Camaro 2010 tires
I've had good luck using the data base at Tire Rack. You can pick "tires by size", enter the size you want, and it will give you a list of all the tires they sell in that size. Then you can filter the list by type of tire - e.g. "high performance all season". Pick a tire from that list, and select the "surveys" tab. The survey results for that tire - dry traction, wet traction, snow traction, braking, cornering, tread life, noise, etc - will be shown, and there will be a link to "see a list of survey results for high performance all season tires".
I've found the survey results to mirror my personal results with the tires I have used, and to match the feedback we get in the "Wheels & Tires" forum.
http://www.tirerack.com/
You won't find "Camaro" reviews.... but the results are applicable to all types of vehicles. In the large size you will be looking for, they will typically be used on larger rear-wheel drive cars like a Camaro. Yes, in the smaller sizes you may find a lot of front-wheel drive ricers posting, but that's not the tire you will be looking for.
F'n1996Z28SS
08-23-2023 11:19 PM
Hurin
12-13-2014 07:38 PM
12-04-2014 11:56 AM
