160 or 180 thermostat
Old 05-03-2006, 09:22 PM
88 irocz 350 5-spd's Avatar
does anyone know where i can get a 160 or 180 thermostat for a l98?
88 irocz 350 5-spd is offline
Old 05-04-2006, 12:21 AM
Gord's Green Z28's Avatar
Re: 160 or 180 thermostat
They're generic small block chevy thermostats. Pretty much any automotive store should stock them.
Did you transplant the 350 in there or the 5 speed?
Gord's Green Z28 is offline
Old 05-04-2006, 12:40 AM
89Vert's Avatar
got to change your fan turn on temps to match
89Vert is offline
Old 05-04-2006, 12:42 AM
89Vert's Avatar
with the gears listed I'm going to guess the 5 speed was swapped in
89Vert is offline
Old 05-04-2006, 12:52 PM
yes the tranny was swapped in the first owner had the dealer do it when he got it new. just had it rebuilt in dec since there was a reason they didn't put t-5s back then behind a l98
Old 05-04-2006, 04:46 PM
Was that the first rebuild on the tranny?
Old 05-04-2006, 06:51 PM
yes that was the first rebuild on it and i think it had around 150k on it not positive though. and the rebuild wasn't cheap either $2300, pretty much the only part they reused was the tranny houseing and everything else was new, all new main shaft, gears, along with a new clutch and flywheel. i would have gone with a 500hp build for it but that ran about $3200 and they wanted $4000 to put a 6 speed in it, but at least it doesn't whine like it use too
Old 05-04-2006, 08:50 PM
Zepher's Avatar
Wow, for that much money, you probably could have had a used T56 installed at a non-dealer shop.
G-Force makes a very very strong T5 rebuild kit for about $1000, look into that next time it breaks, or the T56.
Zepher is offline
Old 05-04-2006, 09:45 PM
yeah i probably could have got it cheaper but that was the whole package with the $600 labor and all the tranny insides and clutch and flywheel. also i didnt take it to a dealer, i took it to ammco.
Old 05-05-2006, 09:05 AM
Unix's Avatar
i see from your sig that u want to go with 3.45 gears ...think that through because on highway runs u arent gonna get high speeds. I have 3.42 on my TBI T-5 and at around 65mph i have around 2500rpm which is way too much for my tastes, but i must admit that the car has excellent launches from start
ps/ i also have the 160' thermostat, when driving the temp is very low and u can feel the extra power the engine has with higher oil pressure and it also takes much longer before the fans kick in when in a traffic jam ... overall i think a 160 is good
Unix is offline
Old 05-05-2006, 10:01 PM
Zepher's Avatar
Originally Posted by Unix
i see from your sig that u want to go with 3.45 gears ...think that through because on highway runs u arent gonna get high speeds. I have 3.42 on my TBI T-5 and at around 65mph i have around 2500rpm which is way too much for my tastes, but i must admit that the car has excellent launches from start.
i've got 4.10's with my 5 speed and I top out at about 125mph (5th gear at 5K rpm), 3.45's in his car should bring him past 150 easily.
Zepher is offline
Old 05-05-2006, 11:49 PM
thats what i was thinking too zepher, cause ive seen people with 3.73s and they still get up to 140. when i put my car in 5th with 2.77s it pretty much idles at 75 to 80mph so i shouldn't loose any top end speed because my car right now doesnt even have enought power to get it past 3500rpms in 5th
Old 05-06-2006, 07:14 PM
You guys are lucky to have 5 speeds in that you can actually top out your cars. I've got the dreaded won't shift into O/D at WOT "feature" on my car.
Old 05-07-2006, 05:52 AM
Unix's Avatar
i had a 2.8 V6 & auto box in my ride last year i swapped it out for a V8 T5 big difference
Unix is offline
Old 05-07-2006, 04:24 PM
Zepher's Avatar
I guess I was really lucky then since my Formula was an auto and it had the B4C package with the WOT upshift to 4th.
http://www.transamws6.com/video/130mph.wmv
Zepher is offline
Quick Reply: 160 or 180 thermostat
