1990 Camaro TPI 305 350 help! please : )
Hi, thanks for taking your time to read this.
I have a 1990 Camaro that originally had a 305 TPI in it. It was changed to a 350 tpi, but the originally 305 tpi was used on the 350 motor. I think this is making it alot slower. are the fuel rails/injectors the same size on the 305 and 350? and if i wanted to get performance injectors for the 350, what size would be good?It also has the originally ECM. Does that make a big difference? also it is an automatic, i want to get a 5 speed manual, what would be a good 5sp trans for racing?Would the 5 speed effect with the ECM? I also need to get a better rear.
I am just trying to find out some mods I can do to make the car faster, but not anything major. If you have any pointers, I would be glad to hear them.
thanks again for reading.
Cory
Shwine617@aol.com
Cory
Shwine617@aol.com
