350 HO Deluxe Swappers
Any info about the swap would be appreciated, such as what was done about throttle and cruise control linkage. Anything else that would save me time and expense would be cool--I assume the hood will close?
JamesCamaro
JamesCamaro
Re: 350 HO Deluxe Swappers
85 IROC (LG4 with T5). This motor will be swapped out for the GM crate 350 HO Deluxe, using the stock T5 for the time being. Exhaust will be Hooker 2055's, Catco high-flow cat, and Hooker cat-back. I'd like to use a Holley spread bore (not the 600cfm which accompanies the 350 HO) so that I can use my stock throttle/cruise set-up--I've been told that this latter will fit--and an L69 dual snorket set-up.
JamesCamaro
JamesCamaro
Henson071
08-04-2015 09:32 AM
