350 TPI TRACK TIMES?? stock
i am looking for the track times on the 1/4 mile for a stock 350 tpi 1990 camaro with 2.73 rear and 700R4 trans.
I just want an idea of what i should be running
thanks
thanks
hmm, because u have been running low 15's, my car was a 305 tpi and was changed to a 350 tpi, with the 305 tpi and computer...i also have a few mods, and I know its know its not because I am a bad driver.
My 89 iroc ran 14.3 bone stock at the track on street tires with the 2.77 BW rear and 700R4. Mild shift improver, but nothing crazy to a rebuilt trans. Motor has 45k on it..... I could see a 13.9 with good tires and a properly tuned motor out of a stocker. Its been done
Will
Will
That's pretty good times Stanghunter. I took my 92 Z (350 TPI) to the track not too long ago for the first time and ran 14.34 @ 95 on the first run with worn out firesone radials and I could not leave on anything above idle. I feel sure with some drag radials and burnout I would be solidly in the 13's, but I want to skip that and go straight to the 12's. Oh, my car is stock (32000 miles) with exception of SLP runners and modified airbox.
Re: 350 TPI TRACK TIMES?? stock
thanks
thanks
THEN IT GOT A STRAIGHT PIPED EXHAUST AND CONE FILTER THEN IT DID A 16.11@88.9MPH.
BUT MY CAR HAS 120,000MILES ON IT.
WITH ONLY A SUPOSED 4,500 MILES ON THE ENGINE.LOL
IF IT WAS REBUILT THEN SOMTHING WENT WRONG.
yes it is. i payed 150 for my hypertech chip. the 24lb injectors well be just right. car should run low 14sec or high 13 sec 1/4 mile times. Good Luck
btw make sure it is for your year of car if not it may not work
Re: Re: 350 TPI TRACK TIMES?? stock
Originally posted by mikey dragster
MY 87 GTA WITH A L-98 350TPI AND A 3.23 GEAR'S RAN A 16.24@86MPH.
when you swapped over to the 350, what cam was used? Those SD systems can get a little funny with an odd cam without prom tuning.
you did mean "I" and not "U" right?
89.99 is alot for one injector.I belivee you can get them for less from jegs or summit as a set of eight.Your car is speed den. not maf right.Computer tune is in store.Maf is more forgiving then speed den.Did you go with a stock l98 or do you have different heads and cam.If everything is stock ,motor, trans, rear, and you only hav the mods listed you should get low 14's high 13's with a set bfg drags out back and shifting just over 5000.Make sure you ice the intake and set the timing at 10 leave just off idle 1200 rpms.Fuel pressure at48psi and disconnect your alt at the track(plug only)
