350 TPI TRACK TIMES?? stock
#16
I think its the injectors.. I didn't say 89.95 for one injector..I said 89.95 for a Jet perfromance chip..is that cheap? I am gonna buy some 24lb injectors too, yea I have speed density. If i get the performance chip, will i need to do any computer work?
thanks
thanks
#17
i will try to get the cam specs tommorow for u, I've been tryin to get in touch with the guy who built the motor, I bought the car with the motor already done, so I only know minor things, so i want to go talk to the guy, I will get ya the specs ASAP geezer powered
#18
I would really go with a pcmforless tuning chip or ed wright.Those jet chips are garbage.If you get the jet chip its plug in and play (or switch chip's rather)If you have the 305 injectors the 24ib is not a bad way to go.You know your in jersey there are some of the best tuners in this state.You can take trip over to cartek in garwood or eastcoastsupercharging by great adventure or even slp.They all have in house tuning.
#20
Well I don't have the link.But just do a search for edwrightchips and you should find it.He does complete custom chips.Pcmforless is also another site to check out.He is very big on this board.Money wise starts at the basic's from 150.00 I believe.Since your in jersey I would go over and see Chris at eastcoastsupercharing.com and have your car tuned on there dyno.I believe you get 2 pulls wide band for 100.00. Then you can go from there with the tuning.Check out there website.
#21
most custam chip will cost 300 or more. Plus u will need to all the spec. for your engine for the custam made chip. I say if the car is mostly stock a stage 2 chip from jet would work great i think. If u do alot of mods than a custam chip is in order. It's all in how much money u what to spend.
teedoff59
08-08-2002 01:36 AM
