Is 3rd and 4th gen rear wheel backspacing the same?
I'm curious if the rear wheel backspacing is the same for 3rd and 4th gen fbodies. I have 2 of each, and want to get a set of draglites (15x8) and need to know if they can pull double duty.
either 10.5 ET Streets (26") or the 28" variant will be going on them.
If they are not the same, what is the backspacing for each?
Thanks in advance!
Thanks in advance!
using a 15x8 wheel with at least 4.5" back spacing will work on both cars using the 26" tall tire. if you want to use the 28" tall tire then a 15x8 with 5.5" backspacing will work on the 4th gen. might be close to the inside on the 3rd gen depending on width of the tire.
BandDirector Blk98ZM6
02-20-2015 07:42 AM
squarehead
11-21-2014 08:02 PM
JasonD
07-15-2002 02:17 PM
