4th gen 5 spd = 88 GTA?
What will and will not work on the GTA?
I can get a 5 speed from a 95 V6 Camaro for 150 bucks.
Ive read that mid-90s and up T5s are stronger (World Class..?)
I did a search here, thirdgen.org, and search engines and found nothing that answers if it is a direct bolt on or what.
Anyone know or have sources with some info?
-Bud
...I also heard that it wont last with the amount of torque in a 350 tpi, but I wont be racing it, and the GTA will likely remain stock. Basically so I will be able to drive a stick well when my 67 Camaro is done (6 speed) along with a few other things.
88 Camaro 2.8 MPFI /67 Camaro /88 GTA 5.7 /AIM: MelancholyVGS311-The Lounge mafia strikes again!
You say that punk to you is what's in your mind not what you
wear, but you know you're so full of sh*t
You scoff at how the cops treat you, but they're no worse than
dicks like you! I just can't understand what you're thinking
-Bud
also... I have heard from a few people that it will bolt directly in (bellhousing and all)
I want to be very good and sure that it will bolt in with no problems... and whether or not the linkadge/pedals/etc will work also
it depends, in 95 there were 2 v6 engines. The 3.4 and the 3.8, the 3.4 is a 60 degree block whereas the 3.8 is a 90 degree block, which is the same as the 350 u have in your car. I have no idea if it will work, but if its a 3.4 it definately wont work, with a 3.8 you have a shot, but don't take my word for sure. If anything, TTT for ya.
Jason Kleinman - 1995 Z28 Polo Green Convertible
Performance Mods: Flowmaster AT w/ Hooker Dual/Dual Tips, SLP Polished CAI
Stereo: Pioneer DEH-P3100, RF Punch 160a2, 2 12" RF Punch Subs, .5 Farad Capacitor, RF Wiring, 5" LCD, DVD
Appearance: Taillight Blackouts
It doesn't matter if it a world class or not, they will bolt up. BUT, since it is from a V6 it has a 14-spline input shaft, which is weaker than V8. Which have a 26-spline inout shaft. Plus V6s have a smaller diameter clutch, and V8 have an 11.5 diameter clutch.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SC3G, GS3, SCFB, SSOA #M01-0391
George P. Lara
1984 Z28
2001 SS #0391
so you decided to go for it? is your dad doin the install or takin it somewhere?
red 89 IROC 5.7L A4
-K&N air filter, Flowmaster exhaust, Hedman headers and Y-pipe, MAC offroad pipe
"THINK OUTSIDE THE BOX"
red 89 IROC 5.7L A4
Dont know yet Brandon. Might go for it, not sure yet. Havent talked to him about it since Ive read these posts.
Its not like we/I will be abusing it, so heh... might go for it
Thanks for the info...
Anyone else with other info/resources is welcome too
-Bud
-Bud
Wait a minute! A trans that originally bolted to a 3.4 60* V6 Chevy has the same bolt pattern as a completely different 3.8L (Buick) V6 and BOTH just so happen to have the same bolt pattern as an 'ol small block Chevy????
You better be DAMNED sure of all this before you slap down the bucks! (No, I've never tried it which I why I'm not going to say for sure it won't work.)
BUT..... Danger, Will Robinson! DANGER!
<font face="Verdana, Arial" size="2">Originally posted by Damon:
BUT..... Danger, Will Robinson! DANGER!</font>
I dont know what is going to happen tho, dont want to ruin the GTA.. but it would make things a lot easier in so many ways
Damon, the T5 from any 3.4 or 3.8, 305, whatever, will bolt up to the bellhousing. They all use the same case. The difference is the input shaft, and the bellhousing bolting up to the motor.
As far as I know, the T5s out of the 3.8 cars has the same 26 spline input shaft, and uses the same clutch & pressure plate, bell housing, t/o bearing, fork, etc. as the V8 cars that had T5s used. I believe it's all identical.
It's the 3.4 motors that had the 14 spline input shaft and different mounting hardware. Remember that the 3.8 has the exact same bolt pattern as a V8, and from the back, looks identical. The 3.4 uses different hardware because that's a 60* block, which is smaller and narrower. It requires a smaller bellhousing and clutch/pressure plate setup, and uses the 14 spline input shaft.
I'm not 100% certain that the 3.8 uses the same WC T5, but I'm sure enough that I'd bet money on it.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
[This message has been edited by Jim85IROC (edited June 13, 2002).]
The IROC Homepage
T5s from '88 and up were world class and were stronger then regular pre '88 ones. The 2.8 and 3.4 V6 T5s used a smaller input shaft and 14 spline disks. You CAN use ANY T5 with your V8, but if you are using a 14 spline one, use a V8 pressure plate and a V6 disk and it works fine. HOWEVER, they are NOT strong at all. I broke 2 world class and 3 V6 T5s (this is old, non WC 14 spline T5s). The cheap 14 spliners lasted 2 weeks each max and they were behind a mild 350 (look at sig for my '88 figures), the world class ones lasted a fair bit longer, but still blew. I got a th350 now. If your motor is mostly stock and you get that V6 trans from a 4th gen, you should be ok for a while. But if you have any kind of power-adders on your motor, forget the T5. I love them driveablity wise, but longevity I hate them. I hate my th350 to tell you the truth, I am gonna look for a Super T10 or something for my ride.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
And also if you need a bellhousing, or more info, just e-mail me at igor455@shaw.ca and I'll help you out. I must have had pulled 10-15 T5s total between mine and friends cars and have had to make all kinds of crap work with my '88 so just let me know.
NewsBot
09-15-2015 11:53 AM
detroitmuscle
07-31-2015 04:21 AM
