4th gen b pillers?
i doubt that the b pillar trim will fit... i dont know if the lengths are the same... what are you trying to do? swap interior from a 4th gen? i've seen that done before. but the dash was the only thing that could be used..
dash, seats and center console, door panels with lots of work, other then that, nothing wothout lots and lots of work
you want to be technical?, all the pillars are named, front to back, first is the windshield frame, "A", next one back is "B", if more, they go
"C", "D", ect.
so yes, the sail panel area would be a "B" pillar, since there is no "C" without a "B"
"C", "D", ect.
Yes they are A,B,C,and D, in that order going from front to back, but the "B" pillar is left out on the coupe (sedans and wagons only)and so is the "D" pillar (wagons) .
