700r4 problems
It could be the front pump seal, the trans pan gasket, the trans fluid fittings, the vent hose, the dipstick tube, the tailshaft housing gasket, the tailshaft seal, speedo cable area, tv cable area, etc etc. The only way to find out is to clean it all off and then run it. Check for the leak.
