700r4 shifting high
700r4 shifting high
89 iroc with 700r4...the car is shifting extremely high. Tried adjusting tv cable makes no difference...whats going on? it feels really loose when in gear driving like it has a high stall
Re: 700r4 shifting high
yeah it seems fine at first until you expect it to shift and it doesnt until around 4k+ it shifts firm(enough to chirp with 275/60/15 Dr's) in 2nd and feels like the converter is stalling instead of dragging the car down like it normally would if you were holding it in 2nd let off the gas and tap it again...thanks gixxer92 once again!
p.s. this is the 3rd tranny the car has had first replacement was B&M then that was "built" by a local shop because it burned up...tranny doesnt have many miles since rebuild under 7k (i know the previous onwer)
fluid doesnt look or smell funny ive burned up trannys before in my 95z...pulled the govenor out...the shaft that goes into the transmission was pitted alittle...im not sure how it works but the cylinder in the middle of it moved some what freely when i closed the 2 arms??? so i cleaned it up anyways no improvment....from what i remember this all started when i manually shifted kind of high by accident while car driving through a parking lot
side note...i can get into 3rd but i have do 70mph or so...not sure about overdrive
FMFRacing88
05-25-2015 08:08 PM
04-16-2015 09:57 AM
