Are 87 IROC gauges mech.????
I'm going to replace my gauges in my '87 IROC with the Z series gauges. I'm getting the Tach., Speedo., volt., fuel., oil press. and temp gauge.
I know the tach. and volt gauges are electric (correct me if I'm wrong). So is the Speedo., fuel., oil press., and temp. elec. or mech.? I want to order the same as I have for ease of installation. Does anyone have any suggestions of how to do this easily? I'm also ordering a Covans classic dash to mount the gauges in the original location. http://www.covansclassic.com/parts/d...3156.33.180.96
Re: Are 87 IROC gauges mech.????
Their electric.
Is there a thick "wire" going from the temp guage sticking right into the motor? NO. Theres a sending unit stuck in the driver side head and then it goes to the guage.
The only thing mechanical is the speedo.
All Electric except Speedo, but Autometer sells an adapter to convert their Electric Speedo to work with the stock mechanical setup.
I've been reading about their speedometer and it sounds so cool. You can recalibrate the speedo by driving a known 2 mile distance, by letting the speedo know the start and stop points.
Let us know how this install goes as I am considering doing the same thing. I will need to replace my fuel guage sending unit at the same time.
Here is a list of the gauges I want. I'll have my mech. check out the cluster for me.
ATM-2604 Gauge, Z-Series, Oil Pressure, 0-100 psi, 2 1/16 in., Analog, Mechanical, Each $38.88 Tomorrow
ATM-2607 Gauge, Z-Series, Water Temperature, 120-240 Degrees F, 2 1/16 in., Analog, Mechanical, Each $59.88 Tomorrow
ATM-2632 Gauge, Z-Series, Clock, 2 1/16 in., Analog, Electrical, Each $66.69 Tomorrow
ATM-2641 Gauge, Z-Series, Fuel Level, Empty/Full, 0 Ohms/90 Ohms, 2 1/16 in., Analog, Electrical, Each $33.95 Tomorrow
ATM-2645 Gauge, Z-Series, Voltmeter, 8-18 V, 2 1/16 in., Analog, Electrical, Each $33.95 Tomorrow
ATM-2694 Speedometer, Z-Series, 0-160 mph, 3 3/8 in., Analog, Mechanical, Each $79.88 Tomorrow
ATM-2699 Tachometer, Z-Series, 0-8,000 rpm, 3 3/8 in., Analog, Electrical, Each $99.88 Tomorrow
CCL-110-82-50921 Gauge Panel, Plastic, Black, Four 2 1/16 in. Holes, Two 3 3/8 in. Holes, Chevy, Camaro, Each $119.95 Tomorrow
gonzo275rltw
3rd Gen / L98 Engine Tech
09-07-2015 04:46 PM
[Interior] Interior protection
themex2002
09-02-2015 03:47 PM
08-07-2015 01:26 PM
