89 IROC....tell me something about his car
Just bought it, its a 350 automatic. Black w/ grey leather and cloth interior. Dont know too much about the F3's and parts availability. Still get all parts thru GM? Or are there aftermarket house's popping up for these cars? Could you get a rear mount cd changer in these cars? There is a pig tail wire stickin out in the back for one. Were 4 whl discs std?
1999 SS #900 Hugger Orange
1969 Z/28 Hugger Orange
1972 Vette Bryar Blue
1989 IROC Z/28 Black 350
Congrats on getting one of the higher end Iroc's. Leather was an option that I have only seen on a few cars.
Aftermarket parts: Its a huge business. GM has cams and stuff like that such as the ZZ9 or ZZ4 cams. There are aftermarket companies for cylinder heads such as Dart and AFR. They make some awesome heads. You can also get Vortec heads and manifold from GM. They flow relatively well. Basically, anything you want is avaliable. Heads,cam,gears,intake manifolds,injectors,headers.... They are all specifically made to fit these cars. Prices aren't too bad. I spent $3000 and am now solidly in the 13's. Other guys with "younger" motors have done it for a lot less. The sky is the limit bro. I figure for another $2000 I could be down in the 12's very easily. Add Nitrous and 11's are a button away.
Welcome to our generation.
My iroc with the lt1 has grey leather, sweet. There are a lot of aftermarket parts for these cars. Some are very expensive and some are resonable. Check out what everyone has and ask around about certain parts that people have on there cars such as whats in my sig and everyone elses. Or you can go to www.tpis.com or some other wed sits and they can help you out. A good suspension is a must on these cars since there getting to be kinda old now. Do some sub frame connectors and control arms, panhard rod, torque arm, new struts, shocks, handling springs. That is a good start. Anyways if you have any question about any certain kind of part im sure we could all help you out a lot more. later
Bobby
BTW: badazz set of cars you have
89' red Iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89' red Iroc-z
LT-1, 4L60E
free mods,chip,no cat, flowmaster
full suspension
Bobby
89' red Iroc-z
386 stroker
Mini ram, 58mm tb
slp cam, 1.6rr
Full suspension
89' red Iroc-z
LT-1, 4L60E
full suspension
For a steering wheel you should get a Grant GT. I have one. Its awesome . Since you have the quick ratio steering box, the smaller diameter of a Grant GT would make it effectively an even quicker ratio steering box. Its too cool when you start whipping through curves at high speeds.
FOr a more specific board jsut dedicated to the 3rd generation F-bodies check out thirdgen.org that site has helped me out more then anyother site when it comes to these cars. they have everykind of topic from cooling to poweradder to motor swaps to carb sections. I have owned 3 3rd gens and love them moving to a 4th gen LS1 by the end of the year. good luck with a great car
86Z28, 355, edelbrock preformer intake and 600 carb., brog warner t-5 with 3.73 posi. 2 1/2" cowl induction hood.
"screw all the haters"
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
