Accel 24# injectors, are they rated 24# according to GM or Ford?
I need to know pretty quick here, I am about to order them from Summit and need to know if they are rated at 38psi like ford or 45(?) like GM?
Brad I was told by Ed Wright not to use the Accel injectors. I didn't ask why. You should email him and see what he says.
I use the SVO 24lb injectors and never had a problem. I would think Detroit Speedworks would have some laying around. I would give Greg or Phil a call.
There seems to be some speculation about the size of the SVO injectors, but I was told they were rated at the lower fuel pressure, so they translate into around a 26lb/hr injector with GM fuel pressure. I decided to split the difference and programmed my PROM for a 25lb injector, and my block learn numbers look great.
