AFPR ?s
Vacuum line ON will lower the pressure u see, when u floor the gas pedal, u lose vacuum, n the pressure raises up to the PSI that you set the regulator to with the line OFF (setting it with line OFF is basically the WOT/Maximum pressure your car will have). If his is 53psi with the vacuum line on, then he's got around 60psi with the line off and that, in my opinion, is way way way too much - so chances are its 53 with line off
Fastbird93
09-29-2015 04:05 PM
Drtryder
04-22-2015 04:17 PM
87Aerocoupe
03-20-2015 01:23 AM
