for aklim 3rd gen ques
aklim i know you stuck a auburn pro series diff in your rear just wondering if you kept your stock axels also what series carrier is that diff or is a carrier something different
Wouldn't it be beneficial to upgrade to 28 spline axles since you are doing all this work to the rear? Axles shouldn't cost more than $125 each new seeing as a 4th gen axle with the trac reluctor ring on it was $130 new from GM.
14
08-11-2015 12:03 PM
ricks95TA
07-23-2015 12:59 AM
cmsmith
07-10-2015 07:19 PM
cmsmith
07-05-2015 07:23 PM
