Any difference between the 2
flows are pretty restrictive... but they have that bad *** sound to them... i'd go with the hooker cat back though. and the smell... you smell gas, or exhaust? if it's gas, could be a clogged cat or your running rich. if it's an exhaust smell.. well... you probably need to replace your header gaskets or check for leaks on the piping
NewsBot
09-30-2015 04:20 PM
